Classic Audi » Classifieds section » Cars Wanted » Audi 200 5T
Old 17-11-16, 09:09 PM   #21
sinbin5t
sinbin5t's Avatar
Originally Posted by randall977 View Post
No, I don't regret it as at the time I needed the money....which I used to fund a couple of other car restorations - one of which I did pretty well from. So now I have the facilities to keep a 200 long term.
What was great about the one I had back in 2008 is that it was unrestored, never been off the road (see photo below - still with gold alloys!). The drive back though London during rush hour in a very tired 200 was crazy...but it made it! I do still have a few nice 5T bits lying around...
I like that bit of history
Would you have a fuel distributor by chance ?
Old 17-11-16, 09:51 PM   #22
randall977
Mr Typ 43!
randall977's Avatar
I'm afraid not, what happened to yours?
Old 17-11-16, 09:59 PM   #23
sinbin5t
sinbin5t's Avatar
Mine suddenly started to screech when the fuel pump primed, it was rebuilt 6 years ago now and i don't know if they can be done a second time
Old 18-11-16, 08:53 AM   #24
randall977
Mr Typ 43!
randall977's Avatar
It's definitely the fuel distributor? It's basically just a plunger which allows more fuel through isn't it? I thought they just cleaned them and replaced the rubber seals...should last more than 6 years!
Old 18-11-16, 09:14 AM   #25
randall977
Mr Typ 43!
randall977's Avatar
Audi 200 5T - BGO 827X is out there somewhere - SORN...
Old 18-11-16, 04:33 PM   #26
sinbin5t
sinbin5t's Avatar
There is a little bit more than that inside one if you open it up, the plate inside can cause a problem if contamination gets in there
Old 18-11-16, 05:01 PM   #27
sinbin5t
sinbin5t's Avatar
Thinking about it, you had a problem with the fuel distributor if i remember correctly, yes ? I know you can get repair kits, but don't think i could manage to do that being a fumble fingers
How did you sort your's out Christian ?
Old 18-11-16, 06:15 PM   #28
randall977
Mr Typ 43!
randall977's Avatar
I had both rebuilt but I don't think there was actually anything wrong with them - most Audi FI problems I've come across are pressure related. You could try here;
http://www.atpelectronics.co.uk/p/au...etronic-1.html
It was £250 for a rebuild back then...
Old 18-11-16, 06:55 PM   #29
garry1
Attachment 10657
Do you know where this car went
X2 200 5e
X3 200 5t auto
X4 200 5t manual
Old 18-11-16, 07:00 PM   #30
sinbin5t
sinbin5t's Avatar
When mine was rebuilt the car had been stood 20 years, this meant that the fuel distributor had emulsified fuel in it and the correct measure of fuel was not produced regardless of the pin position. I get what you are saying about fuel pressure and at the moment i have dry plugs with a very sooty deposit on them, the car will fire up and tick over for maybe 2 mins tops, then it cuts out and will not start again for hours, strange thing is it doesn't smell of fuel as if flooded so i am a little lost.
There could be another explanation that i will email you about.
