Members: 19,823 | Total Threads: 40,097 | Total Posts: 471,134 Currently Active Users: 6583 (0 members and 6583 guests) Welcome to our newest member, BuddyInons |
#21 |
I never trust the timing marks on these engines. Just do as Stuart and I suggested then you are sure everything is set up correctly.
Also when it still does not start try adjusting the CO mixture screw slightly. |
#22 | |
This is what I can tell you so far: 1. Flywheel '0' marking can be seen in bell housing. 2. Distributor rotor arm pointing to timing mark. 3. Camshaft pulley on the correct way and timing mark can be seen through rear cambelt cover. 4. Fuel pump primes when ignition put on. 5. Fuel on spark plugs. 6. Plugs sparking. 7. Plug leads on the correct way. 8. Can not see any cracks in the rubber boot, although the big hose underneath the car is rotted and holed. Unable to alter CO mixture as I need to go an buy a long 3mm allen key. How easy is it to pull the injectors out on these engine? |
#23 |
Going to have a look at these tomorrow:
KV and possible more engines, fuel filters; 1-Fine filter in the tank,can be holed with a coat hanger and not really needed 2-Pre electric pump inline filter, can be cleaned and re used 3-Main canister filter after the pump, renew evey few years 4-Fine filter, from the main feed to the fuel distubutor,banjo fitting 5-Fine filter, banjo on the WUR,feed from the top of the fuel distributor to the wur |
#24 | |
#25 | |
Two pictures. First shows how it was and second, how it is now. ![]() ![]() Last edited by Steve; 21-02-16 at 09:12 AM. |
#26 |
Sorry, I'll ask again, did You get first cylinder on DTC and checked if rotor arm is on position for ignation on first cylinder?
#27 | |
What I did notice today was that the car has had a brand new fuel pump and fuel filter. Although I notice there is a pre-filter from the tank to the fuel pump. Can this be self cleaned or does it need replacing? ![]() ![]() |
#28 |
If there is petrol I would not worry about the small fuel filter now. CO mixture screw is very important and sensitive on these engines, so yes get the allen key to be able to adjust it.
Also you can try the following: - remove the big rubber intake hose - lift the metering flap slightly - try to start it and play with the throttle while starting. It doesn't tell you much but it might start ![]() Getting the injectors out can be hard, they are held in by rubber o-rings that will go hard making them difficult to pop out. Also there should be a rail making sure that the injectors can never pop out by themselves but that is easy to remove. Get new o-rings before you try to get the injectors out. |
#29 |
Is the beast running yet? I am going to be following this as I will be attempting to start a car after 15 years without a start!!!!
Sent from my SM-N910F using Tapatalk |
#30 |
Shameful as it may be, I've not been near it since......other than to walk past it to get in the SWB car.
Going to have a serious think this weekend about what to do with it. Restore as standard, put a 20VT in it or just get rid and concentrate on my other cars. |
