Classic Audi » Technical » Mech/Tech » Suspension & Brakes » 1989 90q judder when braking
Old 17-02-12, 12:55 PM   #21
SteveT63
SteveT63's Avatar
100%
T85 1985 90quattro I5 20vT
T81 1983 80 Sport Red
T81 1983 80 Sport Silver
Old 17-02-12, 03:46 PM   #22
Can I get the discs machined?
Old 17-02-12, 03:56 PM   #23
TeXerv
TeXerv's Avatar
If the thickness isn't out of tolerance, yes. But depending on the disc type, machining isn't always cheaper than buying new ones. You must mind, that machining abrades material, making the discs last even shorter.
TeXerv is offline   Reply With Quote
Old 17-02-12, 05:11 PM   #24
EA262
Interesting link recently posted on another forum
http://www.stoptech.com/technical-su...nd-other-myths
EA262 is offline   Reply With Quote
Old 17-02-12, 07:35 PM   #25
I would rather buy cheap new discs,than to have the old ones machined close to their tolerance.
Look on Ebay,cheap as chips.
KARL.
Old 19-02-12, 08:30 PM   #26
iconauto
little update on this. fitted new shock inserts and top mounts today. still vibrating. checked everything was tight. no play in that i can feel by rocking the wheel at 3 and 9, or 12 and 6 o'clock
so.... as it stands, new track rod ends, new wheel bearings, new shocks and new top mounts (and no difference)
iconauto is offline   Reply With Quote
Old 19-02-12, 08:33 PM   #27
type81
type81's Avatar
Whens the last time the discs were changed?
Old 19-02-12, 09:20 PM   #28
TeXerv
TeXerv's Avatar
Dis Co dis way, Dis Co dat way
Old 19-02-12, 09:39 PM   #29
type81
type81's Avatar
And the problem will be solved. Maybe not
Old 19-02-12, 09:47 PM   #30
TeXerv
TeXerv's Avatar
The symptoms will be solved, of course. The judder is caused by the discs, I've no doubt about it. May be the discs become uneven by overheating caused be sticky caliper pistons?
