Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,133 Currently Active Users: 4196 (0 members and 4196 guests) Welcome to our newest member, BuddyInons |
#21 |
Smut Meister
Don't know if this will help but according to Haynes typical wiring for ignition switch is:
Black/Yellow (1mm) - Electric Window/Central Locking/Door contact switch loom Grey/Yellow (1mm) - as above Red (2.5mm ) - live feed from relay box Black (2.5mm) - negative Red/Black (2.5mm) - negative Red (0.5mm) - live to buzzer for sidelights/radio Grey (0.5mm) - side light/radio on buzzer Brown/Yellow (0.5mm) - side light/radio on buzzer Good luck
Rod Inwood - Member 1467 1994 C4 4a 100 sport 2.6 V6, Ruby Red Pearl, 98,000 miles Previously owned :- 1988 B3 Coupe 2.3E 5 Cyl, Panther Black Metallic 1990 C4 4a 100 Saloon 2.0 ltr, Tornado Red 1994 B4 Coupe 2.6E V6, Lime Pastel 'Gelbus', 231,000 miles (Sadly written off 04/07/2015) ![]() 1994 B4 Avant 2.6E V6, Indigo Blue, 167,000 miles. |
#22 |
All sorted!Now just remove everything that disturbs my eye, put car back together go home and then hit the town feeling all good about myself!
God, I'm happy!
80TDI 1.9 Avant K-reg now gone at 271500 miles A6 Avant 2.0 TDI 'cause it's pointless driving anything but Audi even if it's not a Classic |
#23 |
Smut Meister
Did you get the door lock sorted?
#24 | |
Banned
Lubricating the actual lock mechanism (on the edge of the door) is an often-neglected service item -- it's exposed to quite a bit of crap as you drive around. My favourite is Halfraud's Spray Grease. |
#25 |
as phil says and i use white grease that you spray on
| Tags |
| 80tdi, alarm, b4-series, theft |
