Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,130 Currently Active Users: 3112 (0 members and 3112 guests) Welcome to our newest member, BuddyInons |
#11 |
You need the ur clutch to go with the ur flywheel.
#12 |
Thanks Steve,
Amanda dropped off what she thought was a UR clutch but it doesn't fit the flywheel quattrokid gave me. It does fit the old 7a flywheel though. Gsf list one for the UR, 240mm they reckon. I'll measure the two clutches I've got and see what I come up with. |
#13 |
Is the flywheel you have the one where the clutch sits inside it?
#14 |
I may be wrong but if you have a 7a flywheel and a suitable clutch, can you not just remove the centre bearing and use them?
#15 |
Thats the flywheel Ive got Steve.
Danny, as far as I know the 7a flywheel won't work with my existing gearbox |
#16 |
Thats good, thats the ur flywheel, just need your ur clutch then, the KV crank spigot and Roberts your Fathers Brother, straight bolt up fit... Dont forget the bearing!!!!!!!!!
#17 |
Yep sorry, your clutch plate won't fit on the input shaft
#18 |
Top Tip also....Try not to bust the plastic diff actuator on the body, when you put the box back in, it so make you swear alot and they are a tad annoying to swap when they are in situ!!!!!!!
#19 |
I can give Amanda her clutch back then.
Oh well, search/spending goes on. Once the daft speed boat is out the garage I can get on with the bodywork I started until I turn up a clutch. Thanks again Steve. |
#20 |
No problem, If you dont manage to get one, I will have a secondhand one available soon with plenty of life in it, when the S2 box goes in the 90.
| Flywheel | Acidburn | Parts Wanted | 13 | 24-11-09 06:04 PM |
| Audi 200 turbo quattro flywheel | quattropower | Parts Wanted | 2 | 04-03-09 08:47 AM |
| Audi 100 turbo engine into non-turbo Audi 100 | pimpdriver | Engine | 18 | 09-05-08 02:18 PM |
