Classic Audi » Technical » Mech/Tech » Engine » Audi 80 Quattro 2.1 Starting after 15 years laid up.
Old 11-04-16, 07:38 PM   #11
GBT4
Originally Posted by cjp0349<br />
What about fresh fuel. The stuff left in the car will have lost its 'combustibility' a long time ago<br />
Good luck and keep us all posted
<br />
<br />
Might be worth visiting the tank, pump and filters for a nospot...? If all looks good, fantastic.... But it might just save your bacon checking...
nospot?
Sent from my SM-N910F using Tapatalk
GBT4 is offline   Reply With Quote
Old 11-04-16, 07:47 PM   #12
Originally Posted by GBT4 View Post
<br />
<br />
nospot?
Nospot.... = have a look....
One of the old Gents I worked with always said looking costs nothing... ( although that's changed in this digital age)...
Old 11-04-16, 07:56 PM   #13
GBT4
Haha I like it. I had the ignition on but didn't register the fuel pump coin on. But wasn't listen for it.
Old 11-04-16, 08:16 PM   #14
The fuel pump will only run and prime then stop once system pressurised, if wired correctly. it might be as simple as a blocked filter thats causing that. Find the + and - of the fuel pump and see if it runs if powered independently....
Old 17-04-16, 04:57 PM   #15
GBT4
So I checked today and the fuel pump primed, I disconnected the starter motor first as I want turn it over by hand once the diesel and penetrating fluid mix has set in over night.
If it turns by hand I will attempt to fire her up providing the old belt has no splits I don't want to run it long but before I do the belt I'd like to know if she will run.
I will also remove the PAS and alternater belt if they don't spin freely.
Old 17-04-16, 04:57 PM   #16
GBT4
Also with the ignition on the fuel gauge doesn't move! I hope this is because it's empty!!!
Old 18-04-16, 05:43 PM   #17
GBT4
So she turns over by hand with the only resistance being from the alternator belt!! Couple of questions!
1. Regarding draining the fuel, what's the easiest method?
2. Is there any benefit in dropping a couple of decent magnets into the tank to attract any metallic rot that may have developed?
3. I'm hoping to turn her over properly at the weekend prior to a cambelt change what would you do? I've cleaned the belt both sides best I can. I'm itching to know if she'll run before I spend money on parts!!!!
