Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,120 Currently Active Users: 9496 (0 members and 9496 guests) Welcome to our newest member, BuddyInons |
#11 |
I'm thinking lambda probe since it's worse when the car is warm. Lambda signal is ignored when the car is cold
However, the cool gauge problem needs to get fixed first.
#12 |
#13 |
Thanks Mike.
#14 |
Hi guys,
I can get hold of a lambda probe for under £10.00,but is it easy to fit? Seems to be just a couple of connections but what about access to it? |
#15 |
It's probably in the catalyst.
it will be a 22mm socket to undo it. Be prepared for a battle.
#16 |
Thanks Mike, i will probably take it to a friends garage and get him to stick it on the ramp.
#17 |
Hi,
just changed the rotor arm. Going to work in a bit so will know if it made any difference. I plan to change one thing at a time. The old rotor arm was covered in black sooty stuff as was inside of the cap.I wiped the the stuff away from inside and will change it soon anyway. |
#18 |
Hi,
just an update,the rotor arm has done the trick,no more hesitation. I changed the cheapest thing first as recommended by our John ! Thanks very much indeed John I bought an Intermotor rotor arm off ebay for £3.50 fitted it today and the Audi is running like a Swiss watch ( touch wood...I don`t want to jinx it ). Maybe it`s not the best make but it will do for now. I would like to thanks all the guys that replied to my post and offered possible solutions . You guys are the ones that make this forum so good. |
