Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Lacquer Peel
Old 01-12-14, 10:09 PM   #11
Sandro
Sandro's Avatar
Originally Posted by jamiecoysh View Post
You could try using 3M finesse finishing compound, its not as aggressive as t cut or or the G compounds. Its quite dear but very good
it probably had a blow in at some point and only had a thin layer of lacquer applied
compound will not help.. these cracks are into the lacquer..
I would spray for example, bonnet at time after one side after another... etc... less headache. and You need just rub off the lacquer dont need to go to metal. after one coat of good primer and paint.
Old 01-12-14, 10:29 PM   #12
Flying Frank
Flying Frank's Avatar
thanks for the ideas and advice guys, will give it some consideration.
