Members: 19,821 | Total Threads: 40,099 | Total Posts: 471,158 Currently Active Users: 13927 (2 members and 13925 guests) Welcome to our newest member, BuddyInons |
#11 |
Sorted, thanks to a home made pressure gauge. Attached to feed line and pressure was showing as 9 bar
. Yet pressing on the plate made no difference to running meaning no additional fuel getting to injectors, so swapped the original metering head back in and swapped tiny filter inside banjo connection and heh presto, pressure ruturned to 6 bar and engine revved without issue. Just need to set CO next time Chris pops round to mine.![]()
#12 |
What can I say
![]() ![]() The Wirral Audi Guru strikes strikes again Honestly I wouldn't have these cars if it wasn't for your help & knowledge Cheers pal
![]() 90q-Cab.2.3E-Ur-S6-b2-80 Sport Member 111 |
#13 |
What filter was it you swaped, the one in the WUR ?
#14 |
No, There is a small filter in the main inlet banjo onto the fuel distributer from the pump/ accumulator. Was collapsed and clogged hence such high pressure on gauge.
#15 |
Well found.
So, lets make this clear for all. KV and possible more engines, fuel filters; 1-Fine filter in the tank,can be holed with a coat hanger and not really needed 2-Pre electric pump inline filter, can be cleaned and re used 3-Main canister filter after the pump, renew evey few years 4-Fine filter, from the main feed to the fuel distubutor,banjo fitting 5-Fine filter, banjo on the WUR,feed from the top of the fuel distributor to the wur Is there any more ?! |
