Members: 25,314 | Total Threads: 40,066 | Total Posts: 470,895 Currently Active Users: 999 (23 members and 976 guests) Welcome to our newest member, uzijiwu |
04-05-24, 06:51 PM | #1 | |
Distributor end float KV
Hey troops
still chasing a regular flat spot on E-Lad My distributor has about 3mm of endfloat but very little side float The rotor arm must be getting pushed upwards as this spins up and the shaft turns faster Anybody aware of what it should be? I'm reluctant just to fire the parts cannon on this one |
05-05-24, 02:29 PM | #2 |
Hi Derek, I have a KV distributor, it is at the unit and I have no plans of visiting the unit till Friday.
07-05-24, 10:34 AM | #3 |
A little end float is normal, though 3mm does seem like quite a lot but shouldn't be enough to upset the hall sender. Side to side play should be minimal.
Still have my RS2 tuck up safe, also a 1992 C4 2.8 Avant quattro and a B3 quattro Saloon G60 conversion in progress. |
07-05-24, 01:01 PM | #4 | |
Then it will spin up to the "correct" position when you are encountering the flat spot. If it cures it at speed, then look to replace or repair the dizzy. Woudl it be possible to use washers to remove that float?
15-05-24, 04:44 PM | #5 |
Thanks guys
Colin any chance of checking yours at some point and seeing how much endfloat there is? |
15-05-24, 06:15 PM | #6 |
Forgot to look last week, text me on Friday.
15-05-24, 10:09 PM | #7 |
