Classic Audi » Technical » Mech/Tech » Transmission » Clutch Slave Rod Material
Old 11-07-23, 10:14 AM   #1
BackintheFold
BackintheFold's Avatar
Default Clutch Slave Rod Material
Anyone know why the rods sometimes use a plastic cap, and sometimes don't?
Is the "cup" in the Sachs slave made of metal?
I'm going to have three shorter rods machined up and test them each for best fit, but would like confirmation that it is ok to use pure metal rods.
TIA!
2006 A3 (daily drive)
1987 MB ur
Old 13-07-23, 08:21 AM   #2
BackintheFold
Three questions:
1-Has anyone used, in any car, a slave rod with metal at both ends? S2 forum says yes.
2-Is the clutch release lever lined with plastic, or is it just metal?
3-Is the cup in any slave cylinder lined with plastic?
1987 MB ur
Old 21-07-23, 04:22 AM   #3
K Simmonds
K Simmonds's Avatar
I've installed clutch slave rods that are just mild steel with a ball shap end and not experianced any problems.
Still have my RS2 tuck up safe, also a 1992 C4 2.8 Avant quattro and a B3 quattro Saloon G60 conversion in progress.
Old 25-07-23, 01:50 PM   #4
BackintheFold
Thanks. I've bought 3 different lengths made of stainless steel to try. (I found an ebayer offering Lathe services)
1987 MB ur
Old 26-07-23, 01:13 PM   #5
K Simmonds
K Simmonds's Avatar
No prolem, happy to try and help...
And to answer you other question, the cup in the release arm is not lined, it's simply a roughly 3/8"'s deep recess that's part of the arm pressing. So mental on metal contact is not a problem.
Old 26-07-23, 09:16 PM   #6
BackintheFold
Marrrrvellous!
Thanks. Just had an email that they are on their way.
Just got to build up courage to do the job again…
1987 MB ur
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
