Home | Register | FAQ | Members List | Calendar | Today's Posts | Search | ![]() |
Members: 42,952 | Total Threads: 40,082 | Total Posts: 471,015 Currently Active Users: 578 (4 members and 574 guests) Welcome to our newest member, Alfonsorks |
![]() Hi all, looking for 1991 Audi 90 (10v NG preferred) wiring diagram, I would imagen Audi 80 would be the same. Struggling to connect wiring loom on to the fuse box, still have several wires without a home, may not even be used but any help would be helpful.
Thanks in advance. |
![]() I have a Haynes manual that has various wiring diagrams. Sadly, I'm without the manual for a few days. Would it help you Colin, or are you looking for a different format?
![]() Obli, since my first post I have found my own Haynes and was going to decipher it today, thank you for your help.
![]() Sandro, wiring diagram is spot on thanks, 260 pages, my head is going to be spinning.
![]() Hat off to you Colin, you're getting stuck into this.
![]() Sandro, 1700 pages
![]() Looking for more information on vacuum pipe work.
In the photo below I am pointing at small vacuum pipe connection on side of throttle body, the car is an Audi 90 quattro with NG 10v engine, the distributor has no vacuum advance on it. ![]() In the photo below I am pointing at a small plastic union that connects directly to the inlet manifold, same car. ![]() In the photo below I think I have found the diff lock vacuum pipe and have indicated its route through the engine bay in red circles, white plastic pipe that comes through a grommet behind the battery, but not got any clue where it connects to, I have attached it to the small plastic union that connects directly to the inlet manifold as it does reach that point. ![]() Any help will be much appreciated, this will sound daft but not looked at the underside of bonnet too see if there is a vacuum pipe layout, as there is on some other cars. ![]() |
#10 | |
![]() Quote:
![]() I only noticed this sticker in my 7A recently, after 20+ years of ownership! Not sure what your issue or intention is but one of the vacuum leaks I had was due to one of those plastic caps (yours is green) with a hole rotted in it! |
