Classic Audi » Technical » Technical Info » Tracking 1988 MB Engined car
Old 07-05-21, 07:57 AM   #1
BackintheFold
BackintheFold's Avatar
Default Tracking 1988 MB Engined car
I have been looking at tracking, and have found 4 different sources of info.
Kwik-fit and Isham Research match exactly.
An extract from an Audi Quattro book matches where shown in degrees (I have had to ignore those shown in mm as I cannot convert them).
A printout from Tyresavers in Franklin with references to years outside of ur manufacture, and reference to S2, vary on several places.
I will trust Kwik Fit to do the alignment.
2006 A3 (daily drive)
1987 MB ur
Old 07-05-21, 09:04 AM   #2
Around Poole, it’s been a long time since the local Kwik-Fit had all the kit to do it. They would happily book the car in (this was well over a decade ago, now), and then express surprise that it’s 4-Wheel alignment.
(Much sucking teeth)
Old 07-05-21, 10:00 AM   #3
You'd be better finding an alignment specialist.
https://alignmycar.co.uk
Should find a place near you.
Old 07-05-21, 11:25 AM   #4
Groundhog
Must say ‘Kwik-fit’ and ‘trust’ are not words I would normally use in the same sentence.
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
