Classic Audi » Technical » Mech/Tech » Engine » MB Ur Quattro turbo intake elbow orientation
Old 21-05-19, 06:07 PM   #1
oliverjl
Default MB Ur Quattro turbo intake elbow orientation
Please could someone tell me which way up the 90deg elbow into the compressor inlet side of the turbo goes? It has a flat section on it, should this point upwards or downwards?? It’s an MB Urq.
Thanks..
oliverjl is offline   Reply With Quote
Old 22-05-19, 12:32 AM   #2
The elbow itself should point horizontal towards the right side wing as you have another right angled hose which points upwards to the igloo on top of the plenum.
The wgfv take off was on the side nearest the manifolds I think - it's been a while.
Old 22-05-19, 05:16 PM   #3
oliverjl
Thanks for the reply, yes I’ve got it fitted but it has a scalloped out corner which could either be on the upper side of the corner or the lower side, I assume it’s to do with clearance for the intercooler.
Old 24-05-19, 06:08 PM   #4
BackintheFold
BackintheFold's Avatar
Flat piece should be in the 2 o clock position when viewed from front.
Old 25-05-19, 05:32 AM   #5
oliverjl
Thanks, thats how I have, it seems tight on the intercooler but must just be how its meant to be.
