Classic Audi » Technical » Mech/Tech » Engine » 87 1.8gt Coupe Misfire
Old 15-02-18, 10:48 AM   #1
5potJacko
5potJacko's Avatar
Default 87 1.8gt Coupe Misfire
I've recently acquired an 87 coupe gt with the 1.8 4 cylinder engine. It has a constant misfire and the previous owner told me this is on cylinder 4. Does anyone have any experience on these engine and if so anything obvious I should be looking for?
Its had a brand new dis cap, rotor arm, plugs and leads and it didnt fix it (again previous owner)
5potJacko is offline   Reply With Quote
Old 15-02-18, 11:09 AM   #2
vagdream
First thing I would do is to crosscheck the initial diagnosis and disconnect No.4 plug lead and see whether the misfire is changed in any way, if not then at least you have confirmed where to focus your attentions.
vagdream is offline   Reply With Quote
Old 15-02-18, 12:33 PM   #3
steveb
steveb's Avatar
A compression check would be a good way to proceed
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 15-02-18, 03:23 PM   #4
M4rkp
M4rkp's Avatar
Honestly, I would discard anything the previous owner has hinted at such as new plugs, leads, dizzy cap etc.....
A compression check and leakdown check is a good way to start, if you get acceptable readings then go on to doing as vagdream suggests. I would be certainly looking at condition of plugs....get yourself a set of inline spark indicators, that way you'll be able to see if you have good spark on all four pots.
Of course, could be a fuelling issue - bad injector/seals - do a test to determine flow rates and spray pattern.
Steady and methodical...don't take anything for granted!!
M4rkp is offline   Reply With Quote
Old 19-02-18, 01:40 PM   #5
5potJacko
5potJacko's Avatar
Solved this within 10minutes of investigation. Although the spark plugs were reletivley new, one wasnt working properly so £250 later and its running spot on! Cheers for all help
Old 19-02-18, 04:24 PM   #6
SwallownAmazon
SwallownAmazon's Avatar
£250 for a spark plug?
Old 19-02-18, 04:40 PM   #7
vagdream
£2.50 maybe for a W6DTC?
Old 20-02-18, 12:16 PM   #8
5potJacko
5potJacko's Avatar
Halfords prices!
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
