Classic Audi » Technical » Mech/Tech » Suspension & Brakes » 1997 A6 suspension
Old 23-08-17, 07:09 PM   #1
Audisimon
Audisimon's Avatar
Send a message via MSN to Audisimon
Default 1997 A6 suspension
Hi all I have a 1997 A6 Tdi Estate Quattro and looking to replace front suspension top mounts, bearings, springs and shocks plus doing the rear shocks and springs.
Where is the best place to get all these bits and bobs from?
Cheers in advance😎
Audisimon is offline   Reply With Quote
Old 23-08-17, 07:31 PM   #2
shaun5
shaun5's Avatar
Your car wouldn't happen to be Green would it? and parks in Parkfield area when you pick the kids up? if it is then i see it quite often on my way home from work.
There are various places to get parts from, GSF, Euro car parts, Audi. Your best bet tho is eBay.
Ive got good suspension parts from a 97 2.8 quattro A6
Old 24-08-17, 06:18 PM   #3
Audisimon
Audisimon's Avatar
Hay buddy no mine is silver.
Was gonna give GSF a shout and also TPS but thought I'd try on here first in case there was anywhere else for recommendation.👍😎
Old 24-08-17, 08:36 PM   #4
shaun5
shaun5's Avatar
tried sending a pm but you are full up.
Old 25-08-17, 07:46 PM   #5
Audisimon
Audisimon's Avatar
All cleared out now buddy. Not been on here for ages and forgot what's what😀
Old 28-08-17, 08:48 AM   #6
Gaz
Gaz's Avatar
Question
I believe the AEL engine A6 quattto has a slightly lower 'sport' suspension ?
would that be the same as fitted to the 2.8 v6 quattto ?
Old 28-08-17, 06:48 PM   #7
shaun5
shaun5's Avatar
Yes the A6 i broke had the same springs as my S6 (Sports springs) they would fit any car (100/A6 quattro) obviously the ride height would be different.
Old 28-08-17, 11:32 PM   #8
vorsprung durch technik
I'm assuming your AEL A6 quattro has the 1BE code,(lower) on the build sticker which denotes sports suspension as apposed to the standard 1BA code? If that is the case then the spring would be identicle to the springs i have here from my Sports suspension 2.8 ACK 30v manual box Quattro. Spring colour code will be a combination of yellow and orange 1 x yellow and 2 x orange. There is also a 1 x yellow and 3 x orange spring, both are sports springs and from my personal experience they will be the same ride height but one will offer an even more sporty/harsh ride as some put it. As an aside the S6 sports springs have spring colour dots of silver and violet as i have also on my S6.
Old 18-11-17, 10:16 PM   #9
Audisimon
Audisimon's Avatar
Gonna check my code and the color codes on the springs.
Anyone ever fitted coilover kits?
