Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,156 Currently Active Users: 14795 (1 members and 14794 guests) Welcome to our newest member, BuddyInons |
Me again. Been driving 80 B2 to and from work the odometer is not working.
Found this in the instrument cluster on the speedo side of the binnacle today ![]() Come of this I assume ![]() from somewhere in here? ![]() 2 Questions I am hoping someone can answer How do I get it apart to find out where the cog came from? Where can I obtain a new cog from? |
No need to take apart.
The cog should be on the shaft that sticks out on the LHS - It meshes perpendicular with the worm drive ( the white /cream coloured shaft) If you are VERY careful you could stick the gear back together with some quick setting plastic weld - I would advise against superglue as it sets too hard and will probably cause more damage than it repairs - however, if I were you I would get a unit from a scrapper and replace just the broken bit on yours. ISTR that the cog is secured with some sort of epoxy on the shaft - may need to GENTLY warm it up to get it off. Mark |
Thanks Mark
That makes sense now. Any recomendations for the plastic weld.... Cheers Ewan |
Fantastic Photo Soren. Is that standard or a repair? What is the circlip doing? - Thats what its doing http://forums.vwvortex.com/showthrea...roken-odometer
Just found this Blog on a late 70's Passat - http://ost-blog.passat32.de/2014/04/...ag-mich-nicht/ Looks the same as mine. Last edited by billy_bunter; 25-06-17 at 08:21 PM. |
Found picture on internet. There is a guy in hungary (?) selling new cogs on ebay... 3D printed cogs...
Thank you. Found the picture link on VW Vortex...
http://forums.vwvortex.com/showthrea...roken-odometer found him on ebay based in Zaalegerzeg i've been there :-). Mine is a 21 tooth :-( Think the one he has fixes the later odometers. I will send him an email. If I am correct in my assumptions my part also fits the early golfs so may be worht him looking into it. Last edited by billy_bunter; 25-06-17 at 12:22 PM. Reason: more infoon the Hungary angle |
#9 | |
https://www.amazon.co.uk/d/Outlet/Ta...ent/B0053WXLVU That's a good fix with the circlip that SorenR found though!! |
As always takes longer than you hoped. I tried a repair using the plastic weld abut it would not take. Even got a washer made at work and tried to use an epoxy whilst in a vice. This did not work as the cog would not grip the rod. I could have glued this to the rod but decided to source a new cog
I ordered a new cog from a bloke in Germany pretty sure he gets them from America. American site - http://www.mediafire.com/file/2hr265...6x/cc.bt.b.zip Euro site - http://speedometercogs-gears.com/aud...eedometer.html Part arrived and I fitted it the other week. Finally got it into the car on Monday night. Note the blob of epoxy to make sure it stays on. ![]() and working :-) ![]() |
