Classic Audi » Technical » Mech/Tech » Electrical problems » Audi 80 1994 immobiliser query
Old 24-07-17, 06:46 AM   #41
Fuse 19 goes to pin B1 of V94 which is the central locking module.
Have you replaced the central locking module already ?
1991 90 quattro
Old 24-07-17, 11:23 AM   #42
rangerovering
rangerovering's Avatar
Hi Mike
No I haven't, is the module part of the pump in the boot?
Cheers
rangerovering is offline   Reply With Quote
Old 24-07-17, 06:36 PM   #43
it is. Alarm / central locking is all one unit
1991 90 quattro
Old 01-08-17, 08:36 AM   #44
rangerovering
Right I'll need to get it lifted out and checked. When i got the car it had this fault, then it disappeared for months now it's come back again.
With any luck it might be an easy wiring fix!
Cheers
Old 06-08-17, 01:02 PM   #45
rangerovering
Pulled the pump out this afternoon, a few soldered connections have gained crusty rust on them and there is a damp film over the circuit board.
I cleaned it as best I could without contact cleaner but so far no improvement, the central locking works fine and the red light on the dash flashes but the car will still not start with the system "live".
Worth trying another pump?
Old 06-08-17, 05:34 PM   #46
Ben
Originally Posted by rangerovering View Post
I also only have one key, which has the single round push button for the torch but no obvious transponder chip. How does this work for disabling the immobiliser?
Have you had the key apart? the transponder chip is a very tiny coil of wire wrapped around a core. Is it still in there?
1992 80 quattro 20vt
Old 06-08-17, 06:22 PM   #47
rangerovering
Hi Ben yes I have and there didn't appear to be anything in there....
Will check again, some say the 1994 cars don't actually have a chip?
Old 06-08-17, 07:20 PM   #48
Ben
Yes, it's not a "chip", it looks like a very small fuse, ~10mm long. If you split the key, you can see the rectangle where it should be.
Old 06-08-17, 07:38 PM   #49
rangerovering
This is what I've got, look like there is something missing?
Old 06-08-17, 08:50 PM   #50
Ben
You would see it, as it will fall out from it's hole. It looks like it's missing.
