Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,153 Currently Active Users: 12013 (0 members and 12013 guests) Welcome to our newest member, BuddyInons |
Only 65k miles! ........and velooor! I like.
Kenneth?........get purse out lad! |
Yes John very nice car with history.
I like that a lot
.......A bit of underside damage? Can't be too bad I would think, probably the tester covering his ar5e knowing the car's going to change hands?MOT history of this vehicle.... Test date 21 July 2017 Expiry date 20 July 2018 Test Result Pass Odometer reading 65,523 miles MOT test number 2306 3813 1618 Advisory notice item(s) slight engine and gearbox oil weeps front section of exhaust rusty esp at joint and mounts rear brake discs slightly rusty vehicle has slight underside damage at o/s centre area etc Test date 21 June 2016 Expiry date 22 June 2017 Test Result Pass Odometer reading 64,404 miles MOT test number 8268 4306 4885 Test date 8 June 2015 Expiry date 22 June 2016 Test Result Pass Odometer reading 64,037 miles MOT test number 1251 1935 5134 Test date 23 June 2014 Expiry date 22 June 2015 Test Result Pass Odometer reading 63,622 miles MOT test number 9791 9447 4130 Test date 29 July 2013 Expiry date 28 July 2014 Test Result Pass Odometer reading 63,093 miles MOT test number 3961 3091 3287 Test date 14 June 2012 Expiry date 17 June 2013 Test Result Pass Odometer reading 62,774 miles MOT test number 4773 1606 2145 Test date 14 June 2012 Test Result Fail Odometer reading 62,774 miles MOT test number 2475 9676 2181 Reason(s) for failure.....Offside Front position lamp(s) not working (1.1.A.3b) Test date 14 June 2011 Expiry date 17 June 2012 Test Result Pass Odometer reading 62,512 miles MOT test number 8092 6526 1144 Test date 11 June 2010 Expiry date 17 June 2011 Test Result Pass Odometer reading 61,388 miles MOT test number 7149 8246 0111 Test date 4 June 2009 Expiry date 17 June 2010 Test Result Pass Odometer reading 60,762 miles MOT test number 5411 2525 9172 Test date 17 June 2008 Expiry date 17 June 2009 Test Result Pass Odometer reading 60,286 miles MOT test number 4725 3966 8125 Test date 18 June 2007 Expiry date 17 June 2008 Test Result Pass Odometer reading 59,631 miles MOT test number 3239 6936 7103 Test date 23 May 2006 Expiry date 22 May 2007 Test Result Pass Odometer reading 58,843 miles MOT test number 1408 0354 6140 |
John, You have too much time on you hands, its dry today you should be out working on your cars.
#7 | |
