Classic Audi » Technical » Mech/Tech » Engine » cold vibrations
Old 06-05-15, 05:59 PM   #1
uxtcmenuts
uxtcmenuts's Avatar
Default cold vibrations
So on my 1984 4000s with the 1.8 fuel injected with an auto trans. When its cold and I start it up and put it in gear it has a bad vibration but only when I am stopped. After it warms up it still dose it but not as bad but only when its in gear and I am stopped at a stop lite. I often put it in neutral until I get the green to go so it wont shake me to death.I have replaced all the sensors just not the cold start senser because it the most expensive. Any ideas on what it mite be
uxtcmenuts is offline   Reply With Quote
Old 09-05-15, 07:46 AM   #2
dansp1
Engine mounts worth a look
dansp1 is offline   Reply With Quote
Old 11-05-15, 11:07 PM   #3
uxtcmenuts
uxtcmenuts's Avatar
been replaced
Old 11-05-15, 11:24 PM   #4
Ringmaster
Ringmaster's Avatar
Are spark plugs OK?
Check HT leads and timing.......
Old 12-05-15, 06:11 AM   #5
Lumpy running as you have described it, sounds like its fuel mixture.
I've no idea on the 1.8 engine, specifically, but in my case, a combination of bad coolant temperature sensor connections, and bad lambda probe caused the engine to run frequently very rich. That's on a 1991 V8, though.
I'd be thinking mixture, though.
I guess that being in gear is a bit misleading, as it's the auto box, and torque converter simply not responding well to the lumpy idle.
What about idle? Is there anything which controls or senses when the throttle is closed, and the car is idling?
(Again- I know next to buggah all about the I.8.)
