Classic Audi » Technical » Mech/Tech » Engine » NG bad starting
Old 25-08-14, 08:15 AM   #1
kens_soup
Default NG bad starting
Is there anything common on the 2.3 NG that causes bad starting? I've just rought the car as a project so service wise I'm changing everything like plugs, dizzy cap, rotor arm etc.
It spins over for ages before it half heartedly fires, and once its going its lumpy, give it any throttle and it seems to cut out as if it's over-fuelling!
kens_soup is offline   Reply With Quote
Old 25-08-14, 08:20 AM   #2
Idle Stabilization Valve maybe?
Old 25-08-14, 08:32 AM   #3
Why is it always oxygen sensor or ISV that gets blamed?
I'll bet it's receiving not enough fuel, not too much. If in doubt, when it stalls, remove spark plug and check if it's wet.
What's the idle speed when warm and does rev limiter kicks in @ 6,8k?
Old 25-08-14, 10:01 AM   #4
kens_soup
I'll have a check! After idling a bit rough for a minute it does clear, run and idle fine!
Old 05-09-14, 08:53 AM   #5
PoloGaz
PoloGaz's Avatar
Does the NG still have a cold start injector? If it does, try unplugging it. (blue plug on manifold) If engine starts better then you have leaky main injectors adding fuel to the cylinders when the engine is off.
It sounds a lot like how my 2.0 10v engine was running. Cranks for maybe 10-15 seconds then fires and runs like sh1t. But leave it for a week and it would fire immediately - all the fuel that leaked into the cylinders had evaporated.
You still got the B3 TDI as well?
PoloGaz is offline   Reply With Quote
Old 05-09-14, 09:28 AM   #6
How unplugging CSV removes fuel that has lowered compression in a cylinder? Of course there is CSV - all KE-jet engines have it.
Old 05-09-14, 09:50 AM   #7
PoloGaz
PoloGaz's Avatar
I dont understand your question.
Old 05-09-14, 10:21 AM   #8
Could be as simple as an air leak?
Old 05-09-14, 10:56 AM   #9
When one injector is leaking, engine starts on 3 or 4 pots [depending on pot count], because petrol has washed away oil, lowering compression in that pot. So how unplugging cold start valve makes this not to happen?
Old 06-05-15, 06:29 PM   #10
uxtcmenuts
uxtcmenuts's Avatar
Did you ever figure out the problem mine dose the same thing.
uxtcmenuts is offline   Reply With Quote
