Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 12302 (0 members and 12302 guests) Welcome to our newest member, BuddyInons |
Hi,
My 80 20v avant is sounding poorly. It was going well then suddenly it's sounding rough and driving with little power. I say it was going well but it has been using oil and smelling a bit after a good hiding lately. A couple of years ago I had a camshaft snap in this engine giving nearly the same symptoms as now. I checked the compression and it was down at near 0 on cylinder 2 which was what happened when the camshaft snapped except low compression was on the number 5 cylinder that time. I've got it stripped down and the camshaft is still in one piece. Cylinder 2 valves are oily and dirty when viewed throught he intake ports. Does this sound like a head or block problem as I'm reluctant to strip it any further till I know if I can get a head gasket as sourcing one was the biggest holdup last time. Is an NG engine gasket the same as a 20v 7a as that would be handy seeing as Andy10v has offered me one if I need it. |
It's a different part number in vagcat, so presumably it's a different thickness
Oily valves and no compression, very worn stem seals? |
pretty sure the 20v uses different oil / waterway paths from the 10v also
I've had a bit more of a think about this. Worn stem seals would mean more oil consumption/oil on the valves but not loss of compression
Could be the headgasket between the cylinder and an oil way? I take it it's just that cylinder that looks bad? One thing it could be is a burnt exhaust valve - what fuel injectors are you running? Failing that, rings I guess? |
Thanks Gaz and thanks Mike.
I've sourced a 20v gasket set from another forum member hopefully. I'll see what state the old one is in when I get to it. Best bet going to Audi for the head bolts ? All other valves for the other cylinders are spotless. I'm running the uprated injector kit, the orange ones I think. I hope it's not a ring burnt out but I'll cross that bridge when I get too it. If I need to get the head rebuilt I think I'll treat it to a wee bit porting and polishing, the car deserves it. |
#6 | |
Less likely to be a fuelling issue then with the move from the hitachis. Let us know what you find out
Been looking into the head gaskets. The 20v engines all use the same gasket with the exception of the 7a which must be because of the larger bore. how annoying! (The 2.0 20v NA uses same gasket as 20vT) I believe the Elring part number for the gasket is 128 220 Part number for the bolts is 034103385C What's with the spiral design? Oil supply? |
Wee update on this.
I got the cylinder head off today and the head gasket has blown between two cylinders. I stuck a puddle of oil on each of the pistons to check it stays there and I'll test the valves for leaks tomorrow. If no leaks would anything in particular cause the gasket to burn out there or just normal head gasket failure ? If I find no leaks I would like to just get the engine back together with a new gasket as we can't work as a one car family too much longer. Anything I should be checking before getting new bolts and a gasket and sticking it back together ? |
How long has that gasket lasted?
I asked the internet and I found this; (i'm no expert) http://www.aa1car.com/library/2005/ic010532.htm So between cylinders points to overheating? I'd get the head checked and skimmed if necessary and spend plenty of time cleaning up the cylinder block. Might need new stem seals and guides too? Did the head need a rebuild when the cam went? |
It lives
![]() Life's been a bit upside down and I've had the CRV to kick about in so no great rush but I finally got the 7a back in one piece and fired up. It has no exhaust fitted due to me dropping the original v6 one to fit the stainless one I had made for our old v6 avant. I had a half hour of no start till I figured I had the dizzy fitted at random. After realising my mistake I was pretty confident it would fire right up so shouted on my boy to turn the key. It did fire right up and he pat his shants and just about left through the sunroof ![]() During the time it's sat out the back with it's engine in bits I've fitted all new bushes, discs and pads to the front, new front wings and have new discs, pads and wheel bearings for the rear and the stainless exhaust to fit. it will be like a new car to me once I'm done. Black leather interior will be next I think then get the rear arch corrosion sorted. |
