Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,153 Currently Active Users: 13198 (1 members and 13197 guests) Welcome to our newest member, BuddyInons |
Hi,
Does anyone knows the weight of the flywheel from a KG engine? |
Hi again,
I need your help if someone knows about the position of the timing pin on the flywheel. I will change my KU engine with KG, but the doner Car have Auto transmition which means that it doesn t have flywheel and i am going to modifie and use mine flywheel without timing pin.Any help it would be usefull. |
#3 | |
“Been raced and rallied”
Well a KV fiywheel is 15kg if that helps. ..
thanks it s something .....
what are you after with regards to flywheel weight
![]() If its as a comparison, the lighter flywheels were fitted to the 7A and RR/3B 20V 5 cylinder engines at around 10.5Kg, though mine still runs perfectly with an 8.5 Kg lightened 3B flywheel
thanks, do you have any idea for the exact position of the timing pin on the flywheel?
Found these pictures once on the internet. Perhaps the pin has the same location?
http://s974.photobucket.com/user/jon...58281.jpg.html |
Well the weight of my flywheel ,KU engine, was 13.7 kg and now is 12,3 kg after i have machined from the engine side to remove the "ears" and put the timing pin for the ignition. in a few days we will try to start the engine end see what we have done....
I attache some photos before and after.. |
Hi, i need some informations about the reference timming pin because i have no spark at all .
Before start to check all the ignition system i want to check the basic settings . The engine is KG with Mac-05 ecu .How many teeths is the timming pin before TDC mark on the flywheel? |
