Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,120 Currently Active Users: 8724 (0 members and 8724 guests) Welcome to our newest member, BuddyInons |
#1 | ||
For sale, my 1986 Audi Sport in Stone metallic grey. This is one of the very last sports registered. I have owned this for about 6 years now but haven't used it since ADI 2011 and I would prefer it to go to someone who will use it and have fun in it
95K Full 12 months MOT as of today. £350 spent on MOT/Service/Rad/Brakes etc Just had new radiator, new discs, pads, front calipers, oil, filter change, and is ready to be enjoyed. Smoked rear lights, smoked side lights, new Full custom made stainless Powerflow exhaust system with 911 tailpipe (not as chavy as it sounds, it just fits the rear cutout in the valence perfect and I tried about 20 different ends to make sure it suited. It's not perfect, there is 2 very small area's of bubbling on the inner lip of the offside front and rear arches.There's a small ding at the top of the n/s a pillar, there's a small crack in the plastic trim below the n/s front light, and the drivers side bolster has the usual wear. Also, the clock dial on the dash is not there although I do have a spare dash if required (no charge). I've tried to be honest on the listing as many people have seen and know the car and although it is a very very tidy example, it is not concours (I am a fussy sod as some of you may know!) She is lowered 60mm all round and is running on diamond cut/polished and colour coded detailed VW Castellet alloys. Matching nearly new Goodyear NCT alloys all-round. Colour coded front and rear bumpers. She is one of the nicest looking sports around in my opinion. Price is £2495 ono with 6 months tax and the private plate will be removed or £2795 ono with the Private plate OKJ 496 but not taxed. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Coxy; 05-06-14 at 07:52 PM. |
Seen this car on many occasions and I highly recommend it
Slightly odd
What is there in the way of history ? How many previous owners ? Original paint work ? Last Cambelt change ? You the drill
4 previous owners
has MOT's from 2007 however, it does have a comprehensive record of everything done to it inc. services which were all recorded by the first owner: 8798 1st service 18975 2nd service 21376 oil and oil filter 24525 service 26090 engine flush and oil change 30784 engine flushed with castrol, then replaced with GTX2 plus Molyslip 35452 engine flushed with castrol, then replaced with GTX2 plus Molyslip 37168 Brake pads changed 37265 front silencer replaced 39830 Oil and filter change, brake fluid change 42893 Oil and filter with GTX2 plus Molyslip 47200 engine flushed with castrol, then replaced with GTX2 plus Molyslip bearings regressed, full 40k service carried out 49150 2 185 x 60 x 14 Michelin MXT TL tyres, front brake pads, offside outer driver shaft boot replaced 51023 Oil and filter change, brake fluid and coolant checked 54640 centre silencer damaged on steel gate stop so section replaced 54668 Rad thermostat and temp sender unit replaced 54713 front n/s out drive shaft gaiter replaced 55629 Oil and filter change GTX Magnatec 58900 Oil and filter change GTX Magnatec, new wiper blades, new alternator belt 62100 New spark plugs Bosch Super 4 W56, Oil and filter changed, rad coolant changed 62879 cam belt changed 62620 rear silencer and rear wheel bearing replaced 64370 2 x Michelin Energy tyres 65460 Oil and filter change GTX Magnatec, new spark plug leads 66474 New rear wheel bearings, new rear brake shoes and cylinders 69539 Oil and filter change GTX Magnatec, battery topped up, full service carried out 71956 Oil and filter change 72282 tyres removed and wheel rims cleaned of corrosion and refitted (these were the original Ronal R8's which were with the vehicle at the time 77615 Oil and filter change, Gearbox oil changed, brake fluid changed, coolant renewed, centre exhaust replaced, new front pads 79280 new plugs and leads fitted 79455 dizzy cap and rotor arm replaced 81197 new n/s front strut suspension damper and bump stop 81569 Oil and filter change 83271 Full service Oil and filter change, cam belt changed and tensioner, brake fluid, plugs 84690 replace faulty wiper control relay 85650 remove exhaust tailbox Oil and filter change I've had it for about 10,000 miles and in that time I have serviced it 3 times, all new brakes, pads, discs and calipers, master cylinder, full stainless exhaust, rear brake cylinders, front wheel bearings, suspension top mounts, drive shaft gaiters, lower balljoints and a 3rd Cambelt change and idler wheel which was done at 91408 so in a nutshell cam belt done at 62k, 83k and 91k (mainly down to age not wear). has had one or 2 oils changes as well! also has original handbook and service book. Last edited by Coxy; 05-06-14 at 09:27 PM. |
very nice, one of the best 80 sports around and rare in this colour. GLWS
If I had the space and coffers i'd snap your hand off. Never thought I would see the day. Deserves a good home she does. Good luck with the sale Coxy
money from the sale will be going to the rest of the NSU TT, so needs to be done!
A very worthy reason for selling I have to say it's just a bummer everytime you sell a so called keeper I'm not in position to bite yer hand off.
very nice car , the rust on the wheel arch, any idea how much to sort that out ,
