Classic Audi » Technical » Mech/Tech » Engine » 80 B2 - WN 2B 5 Carburetor Repair Kits?
Old 08-01-14, 06:05 PM   #1
atco1
atco1's Avatar
Default 80 B2 - WN 2B 5 Carburetor Repair Kits?
Anyone know of if you can still buy carb kits as need to recondition a carb on my B2 WN engine with 2B-5 zenith carb on it. The carb i've got has a flat spot when rev it from idle, but I want to recondition the old carb which did work perfect on it until it starting overfilling with fuel inside.
Any ideas please
atco1 is offline   Reply With Quote
Old 08-01-14, 10:21 PM   #2
Stanson
Try to find Meat&Doria repair kit S6G and compare it with your carb:
http://www.meat-doria.com/product_meat/S6G
AFAIK, Zenith was bought by Pierburg, and I don't think they change 2B5 a lot after purchase of Zenith.
Stanson is offline   Reply With Quote
Old 10-01-14, 10:45 AM   #3
al_bundy
I have a good experience with this kit and seller on ebay:
http://cgi.ebay.co.uk/140826596856
Further, the pull-down unit (to open the 2nd throttle plate) also fails after many years.
New ones are rare, but: http://cgi.ebay.co.uk/380738526957
al_bundy is offline   Reply With Quote
Old 10-01-14, 02:07 PM   #4
atco1
atco1's Avatar
Thanks for the replies, very helpful indeed. I've bought the kit off eBay suggested in link. Did try meat doria but can't find a dealer to buy a kit off. When I get the kit I'll do a full carb rebuild think it may be a diaphragm which may of had it on the carb at moment. Thanks again for response
Sent from my C6603 using Tapatalk
1983 B2 80-CD Making a return...
1983 B2 80-CL At shows this year!
1983 B2 80-Quattro In resto process..
1992 B4 80 2.0lE Daily Runabout..
1994 B4 COUPE 2.0l 16v Daily Runabout..
Old 16-01-14, 02:18 PM   #5
atco1
atco1's Avatar
Bought a Haynes manual and the repair kit, rebuilt carburetor now Just needs testing
Old 13-05-15, 06:18 PM   #6
LuisGomes
LuisGomes's Avatar
Default Carb problems too
Hi there! I have the same kit and the manual to, but i dont try to repair my carb yet.
Do you solve your problem?
My engine, sometimes when gets the normal temperature rpm gets up to 2000 several times.... I have to "slap" the accelerator to get rpm down. I run a few more meters and when disengaging the engine or set foot on the clutch, the rpm sets at 2000 rpm or more... again and again...
regards
LuisGomes is offline   Reply With Quote
