Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,118 Currently Active Users: 1160 (0 members and 1160 guests) Welcome to our newest member, BuddyInons |
#11 |
You can fit these headlights from a bova futura it does mean you have to play with the wiring as they are only dip beam and depending on your car you may need to massage the end of the inner wing as they are a lot longer than the originals but they do fit in the original mountings
[FONT] '76 Leyland Princess 2200 HLS '79 Scirocco storm '84 WR '89 coupe quattro '01 A2 1.4 TDI SE '14 A3 1.4 TFSI COD [/color][/size][/font] Last edited by steveb; 16-12-13 at 09:58 PM. |
#12 |
This is great info, thanks guys
#13 |
I looked into this recently out of curiosity. There is a lot of info on the net good and bad but there are kits available with particular bulbs which are design to work with reflector (old style) headlamps. These bulbs have a black stripe up the side and have an R designation instead of an S D2R for example. Another misconception is the bulb rating, the higher number is not a good thing and creates more glare and give a blue or purple colour to the lamp, between 4000k and 6000k seems to be the best option.
#14 |
I changed the wiring on my quadlamp using 3 relays and a 16mm sq fused cable from the battery (I can email a circuit diagram if interested), It made a MASSIVE difference, especially when used with these new brighter halogen lamps and especially on main beam. I have them on my present Cq too and they are like WW2 searchlights on main beam and put the Zenons on the A6 to shame
You do need to have perfect reflectors which tends to be the big issue on these lamps
#15 |
http://www.ebay.co.uk/itm/3211911833...84.m1438.l2649
this sort of thing will help, the problem is usually a voltage drop to the bulbs as 20vcq says, HID are an MOT fail in any case http://www.madelectrical.com/electri...adlights.shtml ok its for an old yank but the principal is the same |
