Classic Audi » Classifieds section » Parts Wanted » b2 hazard switch
Old 03-11-13, 09:03 AM   #1
vag2109
Default b2 hazard switch
Hi,
does anyone have a b2 hazard warning light switch that they would like to sell? The one in my car does not work and it`s causing havoc with my indicators.
Thanks.
vag2109 is offline   Reply With Quote
Old 03-11-13, 05:52 PM   #2
BigT80
They seem to play up if not used for a bit. I had same on a recent MOT and just kept switching on and of numerous times and eventually the buzzing went and it started working and I left it going for 10 mins and then off for MOT with no probs. I might just have been lucky, but to anyone who has these type of models I'd suggest giving them a try every few months. If you do that they seem to keep working .
I may have sparey, but do you need the early type or the later facelift version? Cheers. G.
Old 03-11-13, 07:37 PM   #3
Val
Val's Avatar
80 or 90 switch?
Sent from my GT-I9100 using Tapatalk
Val is offline   Reply With Quote
Old 03-11-13, 08:00 PM   #4
ChrisG
ChrisG's Avatar
I've had success in dismantling ,cleaning & rebuilding ( and wiring in LEDs instead of the 'old' style bulbs that seem to last no time at all).
Old 04-11-13, 12:41 AM   #5
vag2109
Hi guys,
thanks for all your replies.Big -T i think you are spot on,it is lack of use that causes them to play up.I will try your suggestion of on/off tomorrow.My car is the later face lift model ,if i can`t get mine to work and if you do happen to have a spare,that would be great.
Val,my car is an 80 sport. Chris,i have tried dismantling and cleaning but it didn`t work on mine.
Old 04-11-13, 06:45 PM   #6
Val
Val's Avatar
I'll check what I have. Basically they are useless for me. Could cost almost only shipping price from Latvia.
Old 04-11-13, 11:25 PM   #7
vag2109
Ok Val,
thanks very much !
Old 05-11-13, 03:36 PM   #8
BigT80
No problem. I'm not home to check until Sunday, but I'm sure I have the later type as well. I know they both fit and you can change the casing, but easier to do a swap. I'll test it first! (Chris, I thought you could probably do that, but whether I'd be successful, I doubt. I have kept ones that have given trouble too; just in case one day that will be the only option!)
Originally Posted by vag2109 View Post
Hi guys,
Old 06-11-13, 09:23 AM   #9
Val
Val's Avatar
Is this what you're looking for? Only these left from audi 80.
I also have audi 90 hazard switches, all 3 tested and lights upgraded with red diodes.
Old 06-11-13, 09:49 AM   #10
How long is "no time at all"?
