Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,132 Currently Active Users: 10470 (2 members and 10468 guests) Welcome to our newest member, BuddyInons |
Good afternoon,
Wonder if someone can help with a quick question, or rather questions! I've seen a set of B2 Coupe gauges that I want to fit to my 80 GL; the guy in the advert says they come with the loom, but on futher questioning he says 'it's the loom just into the console', so by my reckoning there should be quite a bit more wiring that should come with it. Is this easy to get hold of or make? Are the senders for the gauges easy to come by? And how do they wire in to the lighting system so they come on with the lights? Are they easy to fit? I have looked in the Haynes for diagrams but they make no sense to me! LoL! Any help very much appreciated! Sie! |
I did someone selling the wiring on ebay a few months ago, but i think you would need to get extra wiring for your senders as its just the loom from guages (that would then connect to wiring from senders)
Im pretty sure Golf Gti 1781cc dx has the senders |
http://www.ebay.co.uk/itm/Audi-VW-VD...item415d31da46
http://www.ebay.co.uk/itm/Audi-VW-VD...item4156d3f604 http://www.ebay.co.uk/itm/OIL-TEMPER...item43bb72f40e I think thats the temp sender that you need |
i fitted a set in my 90 CD and my 2 door, the loom just replaces the original one.. think the only sender you need then is oil temp, it was wired on my 90, but i got a temp sender i had spare tapped into the location on the oil pump, if that helps any..
CRASH VALLEY CUSTOMS get 'er done...
How hard it is? Easy. Ok, you can argue that it's easy for me , as I'm able to put together climate control from pile of various parts, but still - it's just three wires + two wires for senders.
http://autolib.diakom.ru/CAR/Audi/19...RAMS/fig07.pdf You think wrong - how about oil pressure, where that will come from? |
That's all really helpful is that guys, thanks very much!
#7 | |
Don't confuse oil pressure switches for pressure warning light relay with oil pressure sender for gauge - it's not prewired and there should be no such sensor in engine.
i plugged it in and the gauge works, im happy with that... however its working... if its good enough for audi its good enough for me..
