Classic Audi » Technical » Mech/Tech » Transmission » 80 TDi Gear oil leak
Old 27-11-12, 09:05 PM   #1
gunman
Default 80 TDi Gear oil leak
Looks like I have a leak from the gearbox on the tdi. It looks like it is coming from the input for the gear linkage which seems a strange place to leak. I didn't think the oil would get up there?
Anyone seen this before and is there a seal which can be replaced here? I take it it's a gearbox out job?
Cheers
gunman is offline   Reply With Quote
Old 28-11-12, 02:03 AM   #2
WOT
With the box out there is a cover on the input flange which houses a seal and a bearing. Easy to change once the box is out. How much is it leaking would you estimate?
WOT is offline   Reply With Quote
Old 28-11-12, 07:15 AM   #3
gunman
Ate you talking about the input shaft of the box? It seems to be leaking from the gear linkage. There's a fair old leak.
Old 28-11-12, 10:37 AM   #4
WOT
Sorry, it was late at night.
I have a housing and a linkage from a 5sp quattro tdi gearbox (A4) if any of that is any good to you.
Old 28-11-12, 11:34 AM   #5
Well, of course, there should be a seal, why else it should leak oil if there would be nothing to go bad Clean it and check if you want be sure.
Several years ago I changed the corresponding seal on mothers mk3 1.6 golf when I changed clutch release bearing, wasn't hard thing to do, had to use hook made from wire to get it out. I guess on audi it should be similar, despite gearbox is totally different.
Old 28-11-12, 12:45 PM   #6
gunman
Yeah, I'm wondering if this can be done without removing the gearbox?
Old 28-11-12, 12:46 PM   #7
gunman
Thanks
I should have a spare gearbox by the weekend for an 80 TDI. Just wondering if there's an easy fix without resortign to gearbox removal.
Old 28-11-12, 12:54 PM   #8
Depending on how easy is to access it - I don't remember how it does looks like, however, I guess, gearshift shaft was on upper side of gearbox?
Old 28-11-12, 01:35 PM   #9
gunman
I'm thinking, remove snub bracket and gearbox mounts and tilt engine and box back?
