Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Advice on bleeding brakes please
Old 04-02-12, 09:19 PM   #11
missfire
missfire's Avatar
no you don't need a crowbar but you could use one if you want.
open desired nipple, depress pedal fully, jam crowbar between the pedal and the front of the drivers set bolster, close nipple, remove crowbar and allow pedal to return fully to its uppermost limit of travel, then repeat the process until all air is dispelled from that brake line and caliper.
useful things crowbars.
one man bleeders are sh*t (i've got one), unless it's a pressure bleeder. i just use a bit of fishtank air line, a margarine tub and a lady with a leg and an ear.
Old 04-02-12, 10:00 PM   #12
saladdodger
Originally Posted by Acidburn View Post
also think you need to make sure the handbrake is off....
I took it off last week when i did the rear, pumped brake then bled, handbrake back on.
I didnt take it off today, just realised.
oooops
Too tired, too cold = mistakes. What a twat.
Old 07-02-12, 05:57 PM   #13
saladdodger
the kit fits on the master so it gets bleed at the same time
put brake fluid in the bottol and screw cap onto the master and the black air pipe goes to the tyre
Right, what a day ive had.
I bought one, done exactly what is says in the instructions but the following happens:
If not enough fluid in the bottle then it runs low and just pushes through air
If too much fluid in the bottle it pisses out of the reservoir cap and once even popped the cap off the reservoir @ 20psi like suggested.
When the cap stayed on but was leaking slightly i couldnt get any fluid to come out of the nipples fast enough, very small dribbles.
Also - no resistance in the pedal and the calipers arnt clamping the discs
WTF!!! is going on.
cheers
Old 07-02-12, 06:50 PM   #14
murran
murran's Avatar
has this got abs? ive had trouble bleeding these old things up in the past. airlocks in the abs pump.
most important is to never let the fluid drain from the system. clamp flexi hoses, stick something on the end of the pipe like a bleed nipple rubber cover thingy.
the feed pipes from the master cyl to the abs pump. have you tried loosening them off at the abs pump while the pressure bleeder is on it.
murran is offline   Reply With Quote
Old 07-02-12, 07:05 PM   #15
saladdodger
It has got abs yes, the system was almost completely drained, i think that would make sense if the air is stuck in the ABS unit, that's why its back pressuring out of the reservoir i guess.
I'll have to try that next then.
Cheers dude
Old 07-02-12, 07:27 PM   #16
Phil Payne
Originally Posted by saladdodger View Post
WTF!!! is going on.
Can you post or PM me your complete VIN?
Old 07-02-12, 07:31 PM   #17
Phil Payne
Interesting. I usually use a yard broom against the head restraint - much finer adjustment using the seat back rake.
Good idea - disconnect the battery, or the rear light clusters, or the brake light switch on the pedal frame. You just wouldn't believe how fast and completely the brake lights can drain a marginal battery.
BTDT.
Old 07-02-12, 08:03 PM   #18
saladdodger
PM sent dude
cheers
Old 07-02-12, 08:04 PM   #19
saladdodger
BTDT.
I didnt do the above as the haynes didnt say do that, i know your website did but i just assume that was only for AUDI UR QUATTRO
Does an air lock in the ABS unit/pump sound like the cause????
Thanks
Old 21-06-12, 09:47 PM   #20
Greavesy
How did you get this resolved in the end?
Greavesy is offline   Reply With Quote
