Classic Audi » Technical » Mech/Tech » Engine » Flywheel issues
Old 06-12-11, 09:45 PM   #1
Foobister
Default Flywheel issues
hi, Can anyone tell me if any flywheel from a five cylinder engine will fit my MC engine or will it have to be one specifically for the engine?
Foobister is offline   Reply With Quote
Old 06-12-11, 10:29 PM   #2
K Simmonds
K Simmonds's Avatar
Pretty much any I5 flywheel will bolt to the crank, but you need an MC or MB(?) unit for the timing pin to be correct.
Old 06-12-11, 10:40 PM   #3
Foobister
thanks for the conformation, I am doing my nut trying to find a flipping flywheel! haha I have (as far as I am aware) everything I need for the 10vt conversion now but can't seem to source a flywheel that will fit. It would be a shame to give up just for that one lump of metal, I am starting to see why the 20vt conversion is more popular!
Old 07-12-11, 01:54 AM   #4
Hanuman
Hanuman's Avatar
Might be a daft question, but would it be possible to mod the flywheel, to install a pin in the right location?
It is, after all, essentially only a pin, that sits in a specific position.
Old 07-12-11, 07:16 AM   #5
Foobister
the big problem is the engine (2.2 10vt) i am planning on using came out of an auto. I assumed the flywheel that came out of the doner (1.8 8v) would be the same but the bolt holes for the crank are wrong.
Old 07-12-11, 07:34 AM   #6
K Simmonds
K Simmonds's Avatar
Have you got the auto fly-wheel? If you have it could be used it to find out where the pin should be, then modify another I5 flywheel to suit.
Old 07-12-11, 07:48 AM   #7
Foobister
Yes I have the auto flywheel, I was thinking to reference the pins as you say, I just can't seem to find a flywheel to buy! I didn't want to just buy any old flywheel if it would be different. Any ideas where I might find a suitable flywheel?
Your help is greatly appreciated
Old 07-12-11, 08:26 AM   #8
K Simmonds
K Simmonds's Avatar
I'll try and have a look when I get some time today, there is an MC flywheel sat in my workshop to measure. I will have one from my 2.3 NG engine coupe going spare before Christmas, maybe as early as this weekend, the car is due to be broken as soon as I get my MK II 16V on the road which I'm working on this week.. Anyway I could compare the two once it's stripped.
Old 07-12-11, 08:53 AM   #9
4v6
Dont forget, you can actually still buy the timing pins from audi for a couple of quid which should save you some hassle, then its a case of finding the position and drilling it correctly to take that pin on an interference fit.
Old 07-12-11, 09:07 AM   #10
Foobister
Would you be looking to sell the flywheel? If so how much are you wanting for it?
