Members: 43,064 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 6645 (0 members and 6645 guests) Welcome to our newest member, JeffreyVak |
#11 |
Audi Coupe Quattro Type 85
I would prefer to sell as a whole , I have worked out that in cost alone this car owes me well in excess of 5k, but If I was to sell complete then I would sell for £4000 20 valve ABY engine, Scat rods, RS2 head gasket, New Audi Piston Rings, ARP head bolts - £1500 Engine just rebuilt 0 miles done since 6 speed gearbox - £350 S2 Prop shaft - £50 S2 Rear Differential - £50 S2 Rear Subframe - £30 S2 Front Subframe - £60 Solid Mounts - £100 S2 Front driveshafts - £50 S2 rear Driveshafts - £50 S2 16 inch Avus alloys with good tyres -£200 S2 Steering wheel VGC - £90 - SOLD AAN Wiring Loom - £200 ABY Wiring Loom - £200 UR Quattro intercooler -£80 S2 Intercooler -£100 S2 Hubs -£250 S6 AAN Inlet Manifold -£100 3B Inlet Manifold VGC - £100 SOLD S2 Exhaust manifold - £80 S2 Wastegate S2 Dashboard -£25 S2 Plasma Gauge Kit - £100 S2 Centre console with diff lock switch -£20 Coupe Quattro type 85 Spoiler -£80 Coupe Quattro Type 85 White wings - £100 S2 Oil Cooler and metal pipes - £100 Audi cabriolet 15 inch alloys with very good tyres - £100 S2 Downpipe - £100 S2 Suspension - £100 Audi Cabriolet suspension - £80 Audi Cabriolet Hubs - 30 Coupe Quattro Type 85 Dash - £25 S2 front seats without frames - £100 7A camshafts - £150 - SOLD ABY Ecu mapped by S2 central - £400 Gearbox mounts 1 brand new - £250 Coupe Quattro Tinted Rear lights vgc - 250 This is what you would get for £4000 20 valve ABY S2 engine Engine Rebuilt using Scat Forged Conrods, RS2 Gaskets, Arp Head bolts, Genuine Audi Piston Rings, Head removed and checked by specialist company, everything put together as Audi would have intended using as many genuine parts as possible. 6 Speed Late spec S2 Gearbox 6 speed Gearbox Mounts 6 Speed gear Linkage Dual mass flywheel Low mileage on clutch Aluminium Spacer plate S2 Propshaft S2 Rear Differential S2 Rear Subframe Cleaned and Painted S2 Front Subframe Cleaned and painted S2 Front Driveshafts S2 16 inch Avus alloys S2 ABY Wiring Loom S6 AAN Wiring Loom S2 Intercooler UR Quattro Intercooler S2 Front and Rear Hubs S2 Front brake calipers and new Disks and Pads S6 AAN Inlet Manifold S2 Exhaust Manifold S2 Downpipe S2 Wastegate S2 Dashboard S2 Plasma Gauge Kit S2 Centre Console with Diff Lock Switch S2 Oil Cooler S2 Suspension Audi Cabriolet Suspension Audi Cabriolet 15 inch Alloys Audi Cabriolet Hubs Audi S2 front seats S2 ABY ECU remapped by S2 central S2 K24 Turbo S2 Strut Brace S2 Air Mass Meter S2 New thermostat Front and Rear Aircraft grade Alloy Subframe mounts Type 85 Coupe Quattro Dashboard UR Quattro Rear Lights Type 85 Coupe Quattro Rear Spoiler Type 85 White Front Wings Full Powerflex Polyurethane Bush kit Porsche 911 Black Calipers Porsche Boxster Red Calipers Over £300 spent in new bolts New track rod ends Many other new parts already fitted Full History of new parts Full Service history including Full Audi service history to 90000 Many boxes of new and used parts |
#12 |
As another option I may swap or part ex for another vehicle also.
#13 |
BTTT
#14 |
BTTT
#15 |
#16 |
She gone hopefully to a good home.
