Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 9351 (0 members and 9351 guests) Welcome to our newest member, BuddyInons |
Hi Guys, what on earth would cause loss of compression on 4 out of 5 cylinders?
Timing correct, Injectors opening fine, Cam chain and belt intact??? It was running fine followed by big cloud of light grey smoke and loss of power. No nasty noises, no fluid loss (Oil and water) Does anyone have a bore scope I could borrow to take a look??? |
Snapped camshaft?
are the valves good or have they kissed the pistons as i pressume the engine turns over
just wonderd |
head gasket blown between the cylinders? like 4 blowing into each other? if you know what i mean? dont know how the hell it would happen though
cracked head????????
Just find it really wierd I would expect a cracked head or bad headgasket on possible 2 cylinders but to get
No.1 4bar No.2 4Bar No.3 0Bar No.4 4Bar No.5 9Bar The dizzy is still spinning so the inlet cam is ok. I will have to get the inlet and rocker off to see. but it's pissing down tonight and I can't be bothered.... It's a 7A by the way.... |
you may have a burnt out valve or seating prob on No3,dose the car run
cam belt slipped around a couple of teeth
voodoo??
I was thinking the valves have 'kissed'. Last year at Race Retro a certain A2 owner had the same issue. The crank bolt was not tightened, came undone, and the second it was felt the ignition killed. However, on scrutiny all was ok, everything turned, no grating or gravelly feeling. But the valves had kissed and that was enough to lose all compression.
