Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Porsche ur Brakes
Old 01-04-10, 10:32 PM   #11
90Quattro
90Quattro's Avatar
with everyone else more details of this conversion is needed now you have teased us!
Old 01-04-10, 11:29 PM   #12
nickt241
fair play,good work,im glad to see im not the only one playing around with bits from other cars.......out ofinterest though,where is the benefit to doing this?,is it that the porsche are 4 pot whereas the audi only 2?
nickt241 is offline   Reply With Quote
Old 01-04-10, 11:33 PM   #13
Hanuman
Hanuman's Avatar
yes.
and whats more, on earlier quattros, they are only single pot calipers. So a good deal for all.
Old 11-04-10, 12:46 AM   #14
nickt241
strange then that a 1972 coupe s has 4 pot calipers as standard but a lot newer audi does not?
Old 11-04-10, 06:19 AM   #15
Hanuman
Hanuman's Avatar
Not so strange from an economics point of view.
The calipers were in widespread use across most of the audi models, so for fitment, only the carrier was model specific.
Old 11-04-10, 07:48 PM   #16
BW2309
oops, sorry chaps - didn't realise this had been replied to!!
I made the carriers to use the original discs. Main reasons for this were so the original 15" Ronals could be retained and secondly, when the brakes are worn later in life it's dead easy and cheap to get a set of standard fit Porsche pads and ur discs. If you use perculiar discs it can be expensive at swap time.
The brakes will fit anything mr Groomington as I measure up and manufacture the carriers specific. to the car.
The carriers made from Dura-Al (aircraft grade alloy that remains strong and rigid even when very hot during braking) would be about £100 including the bolts. That's what it costs me in materials and machine hire to make 'em. You CAN use bigger discs if you wish but if anyone needs a set making up to use standard discs I have the drawings so canm make em without seeing the car.
It's easy to pick up the callipers on flea-bay for about £150-£200 depending on condition, usually including a set of pads! Standard flexi hoses fit straight on without mods too - bonus!!!
Old 18-04-10, 12:57 PM   #17
crisarc
sounds good i am in need of new discs shortly, and already have porsche front calipers, but discs are machined s4 items , any dimensions on caliper hole centres,to see if i have the same caliper?
brakes currently on 200qt, it would mean i can use my 8x15 ronals in the winter,maybe i should just visit you where are you?
Old 18-04-10, 04:09 PM   #18
Hi Ben
Just to stick a spanner in the works.... Could/ would B5 RS4 cailiper fit Ur rims? I have sourced a set of RS6 discs and calipers so the standard ones will be for sale once swapped over, failing that I assume they bolt straight onto B5 S4 as well without mods required?
Old 18-04-10, 04:27 PM   #19
BW2309
Trouble there mate is that the standard B5 RS4 calipers are still teves type sliding calipers so not much of an upgrade over the S2/20v ur set up. They're a bit bigger but not as rigid or powerful as the Porsche 4/6pots.
Much more difficult to retro fit them too as they have a seprate carrier that bolts directly to the hub so if the bolt spacing is incorrect (which it will be) then you can't make a new carrier to fit them.
Same story if fitting to the B5 S4 too.
RS4 discs great but callipers were always a weakness due to their design. Sorry chap!
Old 18-04-10, 07:13 PM   #20
martinjs
Hi Chris you have boxster s front calipers iirc, it was me and spink who did the conversion on the gold 100 you aquired from him, check the part numbers on them, should read 996.351.425 and 426. I made the brackets. larger pistons than the boxster rears and for a wider disk, 28mm thick disk on the front of the boxster s, but 30mm can be squeezed in.
Martin
1992 UrS4
martinjs is offline   Reply With Quote
