Classic Audi » Technical » Mech/Tech » Engine » S2 Coupe strut brace???
Old 15-02-10, 12:19 PM   #1
swiggett
Default S2 Coupe strut brace???
Hi
I have been informed that a genuine S2 coupe strut brace will fit a ur quattro coupe turbo ?
If this is correct would anyone have the Part Number so my local Audi dealer can look it up to see if it is still available.
Yours Hopefully
Simon
swiggett is offline   Reply With Quote
Old 15-02-10, 12:23 PM   #2
I believe so I did have the part numbers to hand but someone has moved them
Old 15-02-10, 12:32 PM   #3
swiggett
Default general chat
Hi Amanda
Would be good if you could find the part number for the strut brace, my ur quattro has been breathed on by Dyrlinx about 9000 miles ago and a strut brace would finish off nicely.
Best Regards
Simon
Old 15-02-10, 12:45 PM   #4
Ok bar is 8a0805645a and you will also need8a0805635b x1, 8a0805636b x1, 8a0805963 x2,893412375a x2 and 171201969 x4
Old 15-02-10, 01:22 PM   #5
swiggett
Many thanks for the part numbers for the strut brace, so i presume it must be true that a S2 brace will fit a ur quattro turbo, would be interesting to hear if anyone on the forum has ever fitted one, or am I going to be a guinea pig ?
Old 15-02-10, 01:30 PM   #6
Andy10v
Andy10v's Avatar
This should be some help, all part numbers and some pictures.
http://www.humanspeakers.com/audi/strut-brace-90.htm
2005 350z GT
Sold-1993 ABY coupe
Old 15-02-10, 01:34 PM   #7
You and me both then
Old 15-02-10, 02:29 PM   #8
What material would you say bar- 8A0 805 645 A 34.95,is made of?
Could you make your own?
Old 15-02-10, 03:50 PM   #9
peanut
yes very easily, its just a square tube bar. Im sure ive got one knocking around here somewhere, will need to check. If ive got it you can have it with those ahem...other bits Karl
Old 15-02-10, 04:24 PM   #10
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Judging by photos i've seen its 20mm Box section with prob 2mm wall. £7-8 for 2metres from metal stockists....
