Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,153 Currently Active Users: 8922 (0 members and 8922 guests) Welcome to our newest member, BuddyInons |
Anyone know of any good options to get more light output from the existing headlamps? It's on an Audi 200. I don't want to put driving lamps on if I can avoid it. Maybe an uprated bulb e.g. the following?
http://www.autoexpress.co.uk/accesso...018-group-test |
#2 | |
They do require extra space behind the mounting (IIRC 70 mm) so measure once and cut twice... er... or something. https://www.youtube.com/watch?v=GM7Lk4YMeKo Russian (sorry) but his test show Osram standard H4 29,2 KLux @ 13,5V and Philips LED H4 75,8 KLux ... Talk about daylight ![]() https://www.youtube.com/watch?v=PfJl-g8N6dU |
#3 | |
Checking for voltage drop between battery and bulb connections on both feed and earth circuits would give you a total voltage drop.......you're looking for as little as possible. I'm not sure if the 200 has lighting relays, maybe it does? ![]() |
Osram Night Breakers
