Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,131 Currently Active Users: 6883 (1 members and 6882 guests) Welcome to our newest member, BuddyInons |
#11 |
Sounds about right!! So G12/13 is a long life anti-freeze but not of the OAT type? So the OP would want this stuff. |
#12 |
Aero Advocate
If we can infer that from my waffle... Just what I have done myself on my b3s and now the b5 - i try and do the right thing by them
#13 |
It's a minefield !
The blue stuff has to be changed every 3 years or so as it 'looses' ( I believe) something that makes it anti FREEZE, the glycol ?? Anyway as I don't mind changing mine ( I always seem to be doing something that results in loss of coolant , rad, stat, hose, oil heater/cooler by filter) so it's never been a real issue ![]() It's a bit like the ethanol in the petrol these days, I use an additive , just in case. B2 Sports were not built for unleaded let alone this other stuff ![]() |
#14 | |
Why do they put Ethanol in the petrol these days? Also, I thought 80's 5 cylinder audis had hardened valve seats, and were designed for unleaded fuels??? |
#15 |
#16 | |
Ethanol ? think it's to do with getting a cleaner exhaust, it makes the exhaust gas smell very different, notice it evertime I back the car out ! Edit -- I should have said they weren't built for the low octane of unleaded ! |
#17 | |
Well, isnt that why it says 98 ron minimum or something like that on the filler flap? Surely it just needs super unleaded? |
#18 |
#19 | ||
Running E85 on turbo cars can have power benefits as you can run more boost/timing due to the octane and cooling effect. (if you map for it and have the injector size to take advantage) As for coolant I just use the Audi stuff and keep a few bottles in the garage as you will always need it for some unforeseen event.
#20 |
I believe the Ethanol content in our petrol is currently still 5%, with 10% planned for the future.
Do you really need to use an additive with 5%? ![]() |
