Members: 19,823 | Total Threads: 40,097 | Total Posts: 471,134 Currently Active Users: 896 (0 members and 896 guests) Welcome to our newest member, BuddyInons |
Hello,
just fitted a mechanical boost gauge to my 1.8t engine off reads 0 engine running reads 20 vac flooring it reads 0 surely it should go above 0? I've tee pieced it between and inlet manifold and fuel rail the car runs and drives fine, pulls strongly for a stock engine.. what am i doing wrong? |
If car is in neutral gear, you can't over 0.
Read the gauge while driving. |
yes have driven the car, still reading 0 boost
Have you pressure tested your intake system? Any faults in vcds?
Does inlet pipe between throttlebody and IC pressurize when runing engine at idle and opening throttle with other hand? |
like i said the car drives fine with no loss of power so i presume the system has no leaks, cant hear any air leeks anywhere
Bad gauge?
brand new? shall email the supplier tomorrow, not had one before so not sure if thats how there ment to work
Hm. Take it off, stand against mirror, blow in it and you should see it go around +0.3...+0.5. Lets see what you're made of.
just tried that manged to get it off the zero, so that should be working
I surrender
