Members: 19,823 | Total Threads: 40,097 | Total Posts: 471,135 Currently Active Users: 8355 (2 members and 8353 guests) Welcome to our newest member, BuddyInons |
As above, my newly acquired 1996 2.0 8v coupe seems to be using excessive fuel.
I ran the tank to empty yesterday then put £5 in, drove to coxy's and back today (very carefully) which is a round trip of 22 miles and the tank is empty again! So the car is doing about 22 miles per gallon if I nurse it which is well below book figures, not only that it seems worse than my old 16V and coxy's 20V! Weirdly the car does not smell excessively of fuel when its idling as you might expect if there was a leak or was running rich. Also I've checked the air filter in case that was blocked and causing havoc with the MAF sensor but that looks nice and clean. If anyone has any suggestions on what to check next that would be great as I'm a little unsure where to look next. Cheers Tim
2000 Audi A4 1.8T sport avant (family wagon) 1996 Audi Coupe 8V Byzanz purple (gone to a new home oop north) 1994 Audi Coupe 16V Amethyst pearl (gone but not forgotten) 1969 Burgundy 912 |
Drop the 16v in!
is it possible you are actually losing fuel from some where maybe filter or similar as opposed to running rich
#4 | |
The fuel pump does have a slight whine but I'm not sure this is of any significance.
#6 | |
if your loosing it when its running/moving you wouldnt notice it so much and the wind would push smells away from you |
Hmm, you might have a point but wouldn't it be losing it when stationary too?
Mine used to run at about the same mpg, pretty much exactly the same! And I never smelt any excessive fumes or anything but changed the lambda sensor and started getting around 35 mpg.
The old one was black as anything, no wonder it wasn't working! Might be worth a look. Also, the cold start valve / fifth injector stick open aparently. You just need to warm the engine up, pop it out and plug the hole then turn the engine back on, it shouldn't release any fuel when warm. Hope that helps ![]() |
Thanks Skinny man, will take a look at both those suggestions.
Problem is, the injectors are pricey (around the £100 iirc
) but easy to fit. The lambda sensor is less so (I paid about £60 I think) but a ballache to fit lol.The cost is offset in what you save on fuel though, at least Good luck, hope you get it sorted. ![]() |
