Classic Audi » Audi Sport / Competition » Competition Cars (FIA/MSA licenced cars) » 1986 Mazda 323 turbo 4x4 Ex-works Group A rally car
Old 02-06-10, 10:08 PM   #231
yeah, she still on Dutch plates, got all the paper work ready to to send of and get it onto UK plates but need a new MOT to do it
Old 22-06-10, 01:23 PM   #232
Been badgering them for all those NLA parts again have we Nige?
http://uk.news.yahoo.com/5/20100622/...p-3fd0ae9.html
Old 22-06-10, 02:37 PM   #233
We it wasn't me, i couldn't even push mine that quick to squash a fly
Old 09-07-10, 05:29 PM   #234
Alpha
Alpha's Avatar
Any relative??
http://www.pistonheads.com/sales/1817580.htm
Alpha is offline   Reply With Quote
Old 10-07-10, 07:00 AM   #235
gabriel.oconnell
gabriel.oconnell's Avatar
hi nigel its a buy one get one free not bad for £7,700 2 rally cars and bits too
Old 10-07-10, 10:44 AM   #236
Originally Posted by Alpha View Post
Not related to me, he's a nice lad from New Zealand
I know he has a few nice goodies in his spares, there both group N cars with a little bit of history, sadly Gabe, at the moment I couldn't even afford £ 7.70 let alone £7700 thats why mine has now come to a grinding halt, no spare cash for the for seeable future
Nige
Old 10-07-10, 11:55 AM   #237
4v6
Is it running yet Nige?
Old 10-07-10, 02:49 PM   #238
gabriel.oconnell
sorry to hear this nigel if i won the big lottery tonight you have 3 by tuesday m8
Old 10-07-10, 05:03 PM   #239
Sort of but only just we now have a working ECU but the rest of the wireing needs finishing and then it needs a map setting up properly
No money, No car this side of Xmas
Old 01-12-10, 06:03 PM   #240
Well its been a slow job since the summer, My buddie Ian has at long last started to work on his kit car and has moved out of my garage and drive. So at long last the Mazie has got back in the warm and we can start to move forward again, very slowly but at least forward.
As you can see we have now ditched the dizzy and running the "Ford" style coil pack so the ignition is fully programable along with the fueling. Time now to find where all these wires go to
More wires !!
Well that was as far as we got
It turned out back in the summer before Chatsworth, the problem was the MAP that was sent over by Omex, not all of it came through, so no matter what we tried it was never going to run. We took the ECU back to them and it was fully checked over and the raw Map was loaded.
At last she fired up into life, very very lumpy tick over but it ran, until we tried to give it any revs, all it would do was stumble and give a tiny little pop back up through the intake no matter what we tried no frigging revs
So back to Omex, had the map and ECU checked again, these were fine, checked and tested all the sensors and these all worked correctly. It turned out to be the injectors were incorrect. The ones I brought from the US were Low impedence and not high impedence so the ECU was not fireing them and seeing though I brought them 15 months earlier I could not get my money back So we found another surplier in the States and £340 lighter the new ones arrived. We also have gone up on the flow rates from 330cc to 460cc and now up to 560cc.
Injectors now fitted and wireing started to get sorted
New MSA reg "Teflon" fuel lines with adjustable pressure regulator with a large Bosch 44 pump at the other end
Downpipe wrapped in heatwrap
As you can see, this is the next real big job, all the wireing needs sorting with a custom built loom
So today we plugged the lappie into the ECU and started to program the sensors, Air temp and Coolent sensors are done one at a time by putting in a cup of boiling water and plotting the readings on a graph in the software as the water cools down all the way to freezing, good day for it as its so freezing cold (the snow came in useful for cooling )
Set up the trottle position sensor and Map sensor as this is need to tell the ECU about the amount of boost as with this system you get rid of the large MAF unit.
Turned the fuel pump on and set the pressure at 5 bar, had a good look around, no leaks, turned the ignition on and prayed
Two turns of the engine and she fired into life
3000 rpm until it warmed up and then she dropped down to a very lumpy 1400 rpm but it runs and we are so happy at last
Its still got a very long way to go before she runs right as this is only on the Raw fire up map and needs to be put on a rolling road to be set up correctly.
Tags
group a, group b rally, group n, mazda, mazda works, rally
Audi 200 Group A Rally Cars, Barn Find Ex-Works hansport Audi sport & history 94 07-09-11 09:42 PM
AUDI-QUATTRO-2-1-Turbo-2dr-WORKS-SPEC-RALLY-TRACK Ebay BIGGYIN Parts For Sale 0 18-11-09 09:36 PM
1986 Audi 200 quattro turbo rally car quattro777 Cars For Sale 9 11-11-09 08:32 PM
Ex-Works Manta 400 rally car hansport Competition Cars (FIA/MSA licenced cars) 13 10-08-09 08:42 AM
