Classic Audi » Technical » Mech/Tech » Engine » Which antifreeze for a 200 Quattro Turbo?
Old 20-12-20, 03:22 PM   #1
Modus
Default Which antifreeze for a 200 Quattro Turbo?
Can it take the red OAT antifreeze? If not, which types of coolant can it take?
Car is a 1987 2.1 turbo model
Modus is offline   Reply With Quote
Old 20-12-20, 05:18 PM   #2
Definitely not red.
You want either G11 (blue) original type or G13 (purple) latest.
1991 90 quattro
Old 21-12-20, 12:09 AM   #3
Gaz
Gaz's Avatar
What's wrong with using the OAT providing whatever was in their was fully flushed out so no cross contamination?
Old 21-12-20, 08:02 AM   #4
The OAT stuff doesn't like yellow metals as far as I'm aware
Old 21-12-20, 05:17 PM   #5
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
I would recommend G11 as this is what was originally used. I have used this in my Coupe GT.
Old 22-12-20, 08:44 PM   #6
Gaz
Gaz's Avatar
Ah I see.. which parts of the engine does it effect?
I'm sure I read that the older OAT stuff had issues of some kind with something in engines but the very latest OAT stuff isn't affected with the same problems?
I don't know if this yellow metal issue was the old issue ? Or if that was something different altogether?
Old 22-12-20, 10:14 PM   #7
Just to pick up on this, I never said for or against OAT.
I specifically said, don't use red
Red is G12 and was only used for a short time when all alloy engines were first fitted to Audis in the mid to late 90s. It wasn't backward compatible with G11.
The latest G13 is backward compatible and can be mixed although a flush is usually recommended.
This gives a decent summary
https://www.ato24.de/en/blog/which-coolant-antifreeze/
1991 90 quattro
Old 23-12-20, 08:09 AM   #8
Anything with brass or copper but I think you're right, it was an issue when the OAT stuff first came on the market?
I would think the owner's handbook will say use an ethylene glycol based antifreeze and to change it every 2 years, at the time it'd be blue in colour.
Old 23-12-20, 12:23 PM   #9
SwallownAmazon
SwallownAmazon's Avatar
Agree with MikeS2 and John - use blue ethylene glycol based antifreeze. Why complicate the issue?
In any cae, even reverse flushing doesn't get all traces of old stuff out and if there is a reaction because of incompatibilty........
Old 23-12-20, 06:30 PM   #10
Mellis46
Aero Advocate
Mellis46's Avatar
Personally I’d go the other way, if you use G13 you can leave it alone and just replace when you do the timing belt / water pump every 6 years as I have. My 90 will testify to zero issues using it over an extended period.
Creates work for yourself having to change the blue stuff every couple of years, it doesnt last anywhere near as long?
Give it a good flush anyway. use the genuine stuff, lets you kick the tyres of the new ones at the dealers while leaving a proper car in the carpark
Mellis46 is online now   Reply With Quote
