Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » My delema
Old 05-05-15, 02:43 AM   #1
uxtcmenuts
uxtcmenuts's Avatar
Default My delema
So I have electric windows in my 84 Audi 4000 sedan and because parts for it are so hard to find and my back windows don't work I am wanting to put manual windows in it but I'm not sheer what will cross with it I think maybe ones out of a VW Rabit will but still not sheer any one have any ideas. Would be a great help.
uxtcmenuts is offline   Reply With Quote
Old 05-05-15, 09:24 AM   #2
quattrostyle
That would mean drilling holes in the door cards as well, can't believe electric window regulators are that hard to come by in the US? Actually I was hoping to find some Audi 4k parts in the US for my cars.
Anyway, my brother is breaking a 90 (Euro version of the 4000) and has manual regulators for you if you want.
Old 05-05-15, 10:42 AM   #3
Worth a little diagnostics and elimination of potential issues before embarking on some mods.
Sticky motors that need a good clean.
Window switches that are easily swapped if you find some.
Mechanisms that need some grease
Poor connections on the window circuit breakers
Dirt build up in the guides and channels
Old 05-05-15, 01:25 PM   #4
SE_30
SE_30's Avatar
Definitely worth investigating if not done so already.
I had the same in my 90. Three non functioning electric windows. Turned out to be faulty switches. I'd be trying that route first.
Is there no Audi's in a breakers yard of that era you could try and swop the switches over? Even if they are the incorrect profile/ shape but the plug on the rear may be the same, just to rule out faulty switches and give them a try before moving on?
B2 90 quattro; next project
B2 90 quattro; half dead
Old 06-05-15, 07:42 AM   #5
Got a spare regulator / motor from a 83 80q for the rear if it's any good ? Might have both of them but will need to check
Postage could be pricey
Old 06-05-15, 04:35 PM   #6
quattrostyle
Broken wires from the B-post to the doors might also be one.
Old 06-05-15, 05:12 PM   #7
Yep.
Also- rear windows? Is there a lockout switch? Lack of use making them slow to react. My v8 did that once in a while.
Old 06-05-15, 05:29 PM   #8
uxtcmenuts
uxtcmenuts's Avatar
well I have replace all i could just not the switches finding new ones has been an ishew and sens the styles changed every 2 years that dose not help but I ran jumper wires to see if it was the switches it was not I rely just don't have the extra money to keep throwing at them I just want the cranks for them and be done with it.
Old 07-05-15, 04:58 AM   #9
Well, don't trow that money and start to look for problems. What happens if you connect just motors to battery - do they run?
Old 07-05-15, 02:13 PM   #10
uxtcmenuts
uxtcmenuts's Avatar
Yes they do I have replaced bolth of them keep in mind this is just the back doors
