Classic Audi » Technical » Mech/Tech » Engine » Audi 100 2.6 running problem
Old 13-11-12, 08:13 AM   #1
hunker7
hunker7's Avatar
Send a message via Skype™ to hunker7
Default Audi 100 2.6 running problem
Hi. I have a problem with my 1993 Audi. When it's cold and when driving around town, when I take my foot off the throttle car is still going for about 3 seconds, but on motorway everything is fine. I checked for leaks around inlet manifold and vacuum system seems to be in order too, and another thing is at some point when engine is cold RPM will jump between 1100rpm and 1200rpm for some time and then stop. I just have no idea what it can be. Maybe someone can help me with that? Thanks in advance.
EDIT : Engine code is ABC.
hunker7 is offline   Reply With Quote
Old 13-11-12, 07:19 PM   #2
Ben
Have you tried cleaning out the idle stabilizer valve with WD40? : http://www.12v.org/engine/index.php?...n=cl&view=rear
1992 80 quattro 20vt
Old 13-11-12, 10:08 PM   #3
hunker7
hunker7's Avatar
No I have not. Thanks for advice, will do that for sure, and update on what is happening.
Old 14-02-13, 07:40 PM   #4
hunker7
hunker7's Avatar
I did clean it, but nothing changed. Bought a new one, still, no luck!
Old 14-02-13, 08:36 PM   #5
Audiden
Audiden's Avatar
Is it manual or automatic?
Too many cars!!
Old 14-02-13, 08:42 PM   #6
Question Might be worth,trying?
Temp sender that controls,the ISV?
I swopped(and cleaned) my ISV three times and no changed.Renewed temp sender and fixed the problem.
KARL.
Old 14-02-13, 10:09 PM   #7
hunker7
hunker7's Avatar
Manual
Yes, I have been thinking about checking temprature sensor. According to AutoData there has to be certain resistance between connectors at certain temprature. Can I just dip it in water and check resistance? Will it not damage it?
Old 14-02-13, 10:41 PM   #8
Cuppatea
Cuppatea's Avatar
Make sure the throttle cable is nice and free and not over adjusted.
Check/clean throttle butterflies).
And finally operation of 'closed throttle' switch.
Cuppatea is offline   Reply With Quote
Old 14-02-13, 10:51 PM   #9
Default Don't know the cost of yours?
The temp sender for my KV engine was,about £6 from GSF.
Easy enough,job.
KARL.
Old 14-02-13, 10:51 PM   #10
hunker7
hunker7's Avatar
Originally Posted by Cuppatea View Post
Make sure the throttle cable is nice and free and not over adjusted. Clean isv as mentioned, check/clean throttle butterfly(s). And finally operation of 'closed throttle' switch.
Checked throttle body cable and cleaned throttle body. If ISV is idle valve then I changed that.
What do you mean by operation of closed throttle switch?
