Classic Audi » Technical » Mech/Tech » Engine » Are 7A and KV bottom ends the same?
Old 29-11-10, 05:11 PM   #1
leehidson
Default Are 7A and KV bottom ends the same?
Just wondered
leehidson is offline   Reply With Quote
Old 29-11-10, 05:36 PM   #2
Pretty much so.
Id suggest there may be some differences with the counterweighting on the cranks for the different piston weights tho, something youd need to address by getting them balanced-just in case.
Its possible there are some other differences tho , so not 100% on this.
Old 29-11-10, 06:21 PM   #3
K Simmonds
K Simmonds's Avatar
7A, NG, KV, 3B, ABY, AAN and ADU all use the same part number Crankshaft.
K Simmonds is offline   Reply With Quote
Old 29-11-10, 06:34 PM   #4
andy e
andy e
The South African 10V 2.3 in my VW uses a 7A head gasket according to Etka.
andy e is offline   Reply With Quote
Old 29-11-10, 08:47 PM   #5
quattrostyle
7A block has oil squirters for piston cooling, KV doesn't
Old 20-12-10, 02:27 AM   #6
vag_nutter
vag_nutter's Avatar
Arent the bores on the 2.3l engines larger than the kv?
vag_nutter is offline   Reply With Quote
