Classic Audi » Technical » Mech/Tech » Engine » What,s the difference between ABY+AAN Engines?
Old 05-04-10, 10:13 PM   #1
Default What,s the difference between ABY+AAN Engines?
What is the difference between an ABY and AAN engine?
Thanks,Karl.
Old 05-04-10, 10:28 PM   #2
missfire
missfire's Avatar
one ends with.....BY
one ends with.....AN................
Old 05-04-10, 10:37 PM   #3
Old 05-04-10, 10:45 PM   #4
The AAN version was the later lump dropped into the UrS4/6 developing 230bhp and 258ft lb, also the intake tract differs from the ABY & 3B in that the AAN inlet manifold is on the right side as you look at it whereas the ABY/3B is fed into the back if the engine block.... I think it also has a slightly less output of 220bhp and 228ft lb of torque... And a different ecu with a revised mapping.
also the AAN spawned the RS2 version which was tweaked by Porsche, I can't say I have seen an ABY/3B specced up to RS2 level
I think the AAN is more accessable to work on as well, also the mating to a 6 speed manual or 5 speed box may have issues as well.I know of 2 S2's that was coded as an ABY 3B with a 5 speed box because at the time Audi had reliability issues on the 6 speed box.
Old 05-04-10, 10:49 PM   #5
Thanks,mate.
Old 05-04-10, 10:53 PM   #6
Essentially the same, especially when looking to use them to upgrade a different chassis altogether.
The big difference was really between 3B (similar to RR?) and ABY (similar to AAN), with respect to ignition components.
I hope to be getting my hands on one of these 4 options later in the year, if all goes well. So any more comprehensive info would be most useful.
Old 05-04-10, 11:14 PM   #7
missfire
missfire's Avatar
Old 05-04-10, 11:22 PM   #8
Had a few sherberts?
Old 05-04-10, 11:27 PM   #9
The reason I ask,is I was stripping my engine(turbo+manifold) and I,m sure I saw AAN on the block?Have to check tomorrow??
Old 05-04-10, 11:29 PM   #10
AAN 5pot
no one likes a smart-arse
AAN 5pot is offline   Reply With Quote
