Classic Audi » Technical » Mech/Tech » Engine » Fuel to engine problem Audi 80 Sport 84'
Old 02-03-10, 06:23 PM   #1
80sport_owner
80sport_owner's Avatar
Exclamation Fuel to engine problem Audi 80 Sport 84'
Hello,
I am experiencing problems with my Audi 80 sport (1984)
Recently my car has been stalling due to what seems to be a lack of fuel getting to the engine. I have tried changing the fuel filter and clearing out some of the crap that's in the plastic reservoir near the electronic fuel pump. (sorry about my lack of knowledge coming out in my writing)
Basically what happens is: I turn the ignition over and can hear the pump working and the relay ticks twice indicating it seems to be working. I will then be driving along and the fuel pump starts making a loud struggling noise then i start to feel the engine stalling with lack of fuel.
Any ideas to answer my probably dumb ass question?
Thanks,
Mark
80sport_owner is offline   Reply With Quote
Old 02-03-10, 10:25 PM   #2
missfire
missfire's Avatar
get a new fuel pump....................
Old 02-03-10, 11:09 PM   #3
Hanuman
Hanuman's Avatar
Does the car run normally for the rest of the time? How long before the symptoms occur after starting?
It could be you are pulling bits of debris from the tank. Have you checked the filters again?
Fuel flow test. Fuel injection pumps for K-jet (I'm going to feel really daft if it isn't K-jet, or even injection) should deliver about 4ltr/min, as measured on the return to the fuel tank. And about 5bar pressure.
There's been some discussion over on the other channel- http://www.quattroforum.com/forum/wr...ving-fuel.html
and here, for the ur, but the basics can be applied to all similar era machinery
http://www.isham-research.co.uk/quattro/fuel_pump.html
Old 02-03-10, 11:09 PM   #4
a new fuel pump would be my first port of call.
Sounds like it could be on the way out. I had similar symptoms with my old coupe a few years go.
Word of advice, Audi can get them but go to GSF as they were less than half the price of what the main dealer quoted and had them in stock.
Old 02-03-10, 11:17 PM   #5
Does it have 2 filters,like mine?Small plastic(gravity)one,then a larger metal canister one nearer pump?
Old 02-03-10, 11:20 PM   #6
missfire
missfire's Avatar
try running it with the fuel cap off..............?? blocked tank vent
Old 02-03-10, 11:29 PM   #7
80sport_owner
Yeah it has the 2 filters. Ill try having the cap off for a while. I just didnt want to go spending money on pumps if it is still working. (student budget)
What happens is ill be driving for about 500 yards then it will stall but fuel pump seems to be struggling. Perhaps there is still shit in the tank. It then starts fine, so im driving along and having to coast for a bit while i turn the key to pump some more fuel in. It then seems to last as long as that small amount of fuel lasts. And yes it is K-Jet and my 'car expert mate' knows sod all about really.
Ta for replies kind people
Old 02-03-10, 11:31 PM   #8
how noisy is the fuel pump???????
Old 02-03-10, 11:42 PM   #9
Hanuman
Hanuman's Avatar
I got the impression that this was happening infrequently. But with it happening so quickly, I'm inclined to think that the fuel pump is a likely culprit.
But. I'm not a fan of replacing things until some work has been done to identify exactly whats happening.
as mentioned earlier
-4ltr/min roughly, checked at the return line.
-5bar pressure minimum, with the system connected normally
-5-8 amps running current, and the pump really does need 12v to work well (there is a relay mod which has been carried out on ur's a lot)
-Fuel pump relays can be at issue, occasionally. Bridging the relay contacts so the pump runs continuously is worth a go. ONLY for test purposes, to identify the problem. If that works, then a new relay. Don't be tempted to run that permanently.
-check the filters again, see if they are full of crap, again. How much did you remove last time?
Old 02-03-10, 11:41 PM   #10
nickt241
check the earth for the pump,chances are it will be corroded and giving an intermittant connection,you can test this by linking in a temporary earth on the negative terminal on pump then driving car to see if symptoms persist,while you are there make sure both positive and negative terminals on pump are secure...if this dosent sort it then change the relay(easy and cheap)also check connections on plug to relay and give them a blast of WD,relays can break down over time as they only contain a wire coil and a set of duel points similar to ignition points........if neither of these virtually free repairs cure it then it will be the pump cos theres nothing left....its doubtful to be tank debris but even if it is then it renders the pump U/S
nickt241 is offline   Reply With Quote
Tags
audi 80 sport, engine problem, fuel pump.
