Classic Audi » Classifieds section » Parts Wanted » Brake Servo Vacuum Pipe
Old 07-01-23, 07:06 PM   #1
Sie!
Default Brake Servo Vacuum Pipe
Good evening all,
Long shot here.... Looking for a brake servo vacuum pipe for a RHD 1985 Audi 80 4-cylinder carb engine (DS), as per the picture below (Top item);
Anyone have one lying around by any chance?
Brgds,
Simon
Old 08-01-23, 06:13 PM   #2
K Simmonds
K Simmonds's Avatar
I might have something from one of the various cars I've broken over the years, got a box full of servo pipes, will have a rummage this week, I'm not that hopeful though as I've not broken any Carb engine Audi's. Done plenty of VW's but their transverse so I can't see one from anything other than a B2 Passat being the same.
Still have my RS2 tuck up safe, also a 1992 C4 2.8 Avant quattro and a B3 quattro Saloon G60 conversion in progress.
Old 08-01-23, 06:26 PM   #3
tractor Dave
I don't think it would be too difficult to make something up. Have you got the old pipe to use as a template?
Old 08-01-23, 07:00 PM   #4
K Simmonds
K Simmonds's Avatar
That's kinda what I was thinking, going to see if I've got something that looks close that could be cut and made to fit. Swapping the fittings is a bit tricky but if you use the sink of very hot water method to soften the plastic up it'd doable.
Old 09-01-23, 09:33 AM   #5
Sie!
Thanks for looking guys, much appreciated.
I have been investigating making a new one as it happens, I can find a replacement one way valve which looks the same as above, and I can also get a new grommet for the brake servo, the bit I’m struggling with is the end of the pipe that goes into the servo.
I’m assuming this is just a push fit into the servo grommet?
If I can get that part I may be able to make a new one from scratch, I just don’t want to rip my original to pieces just in case, I’d like to keep that as is because I’m not even 100% sure there’s anything wrong with it.
Old 09-01-23, 05:59 PM   #6
K Simmonds
K Simmonds's Avatar
What’s wrong with your current one? The oneway valves are generic VAG parts, I’m sure I’ve got an old servo pipe with fitting on the end to locate into the vacuum reservoir.
