Classic Audi » Technical » Mech/Tech » Transmission » 20v 7a into b2 90Q
Old 09-07-15, 04:40 PM   #1
willow
Default 20v 7a into b2 90Q
When fitting a 20v 7a engine into a b2 90. Quattro, do I need a flywheel and clutch from a ur Quattro?
willow is offline   Reply With Quote
Old 09-07-15, 04:46 PM   #2
pauliusb2
flywheel from rr quattro or audi 200 turbo,clutch of 7a
im using 200 flywheel for my 3b conversion,i been told that 200 flywheel is lighter then others
pauliusb2 is offline   Reply With Quote
Old 09-07-15, 05:48 PM   #3
willow
Thanks for the reply.
WHat have others used out of interest. What would be the best option with regards to availability?
Old 10-07-15, 03:12 PM   #4
willow
what other options are available?
Old 15-08-15, 06:02 PM   #5
PoloGaz
PoloGaz's Avatar
I've just done this conversion, but to a fwd car
I used a 2.2 'kv' engine flywheel and clutch. I got a timing dowel put in the correct location for the 7A engine management. The URQ flywheel already has this, which is the main reason you need a URQ flywheel.
I thought the URQ and KV used the same type of stepped flywheel so you'd need to use a URQ clutch. A 7a flywheel is flat.
you also need to put a pilot bearing into the crankshaft
PoloGaz is offline   Reply With Quote
Old 21-08-15, 10:35 AM   #6
willow
thanks! thats the type of info I need!
Any more info on the pilot bearing you used?
Also how did you locate the new timing towel exactly, just measurements?
Thanks
Regards
william
