Members: 19,823 | Total Threads: 40,097 | Total Posts: 471,134 Currently Active Users: 2553 (1 members and 2552 guests) Welcome to our newest member, BuddyInons |
does anyone know how reliable this engine is? a friend of mine is going to
look at an A4 avant and i have no idea about this engine. it's only done 119k miles and the story with it sounds genuine enough . . thanks.
1997 Audi S6 Ruby Red |
I'v heard nothing but bad things Craig.Camshafts wear on early ones not sure about later one and it seems there is too much to go wrong and when it does your looking 4 figures to put right. The 1.9 tdi is a much better bet and are very very reliable Apart from N75 valves and the odd sensor.Sensors are cheap enough and N75 valve from G@S about £75.Plus you can chip a 1.9 to not far short of the V6 power wise.
Try Googling it you will see the negative comments. |
Yep heard about the soft cams until 2003/4 at some point. But also heard they ain't very economical at all if driven hard. May as well stick to petrol unless you get diesel for free. 2.7t! Perfectly economical in this day and age of global civilisation collapse/oversupplied energy market/tumbling/ed crude prices. Diesel engines are for vans!
Over here we can hear mostly negative comments as well - a lot of people write in internet that 1.9 is better etc. There are two main problems with it - first one - valvetrain requires oil according to VAG standard, specified to that engine, and second one, there sometimes happen some problems with fuel pump, either mechanical or electronic. As for valvetrain, some people believes that the change in 2003. should have made any difference, which means - they believe that these newer engines don't require good oil
Some today estimate that this engine has resource of about 350k km - in the past I've read that problems with poorly maintained engines begins @ 200k. My cousin bought early C5 A6 2.5 TDI avant with AT - he sold it recently, because it was second car in a family for three years - engine was working like clock - apart from maintenance and replacement of MAF, which could happen. I presume that those who don't have any problem, just drive and don't write bold comments in the internet - that's why there's that poor reputation. If you seriously want to buy one - best way is by removing valve covers for inspection, which, of course, involves new gaskets, but most sellers, especially in the UK, shouldn't be willing to do that. Persons with experience might try to make assumptions from that small part of one camshaft that is visible through oil filler. P.S. I remember that here was similar thread some time ago, with only positive comments ![]() |
thanks for your comments chaps - he's going to view it with those thoughts in mind.
I have A late 2001 A6 quattro with the 2.5 V6 (180ps) and apart from the fuel economy (32-34 average, up to 40mpg on a long run) it has been awesome, got it at 112,000 changed the belts n pulleys and its now over 160,000 without missin a beat
1985, 80, slighty modified 1986 80 Quattro Project 2001 A6 Quattro Sport TDi and a few Kawasakis
