Classic Audi » Technical » Mech/Tech » Suspension & Brakes » C5 A6 Brakes stuck on
Old 28-04-13, 08:43 PM   #1
Thompy
Default C5 A6 Brakes stuck on
Hey guys, first of all apologies about the no classic content, but I'm a bit stuck (literally)
My car is a C5 A6 2.7Tq
Went out this afternoon to take some boxes to the local recycling centre. About a quarter of a mile from the recycling centre I pressed the brakes, found the pedal hard and the brakes seemed to be binding (not releasing when I released brake pedal). The binding got worse and by the time we got to the recycling centre the car was really straining against the brakes. Emptied the car and decided to try to get home, when I tried to set off the brakes seemed to be solidly on and the brake pedal was rock solid. I tried a couple of things - disconnected the vacuum hose to the servo and pulled the plug on the ABS pump. Neither had any immediate effect, but after about half an hour, once the car and brakes had cooled there didn't seem to be the same degree of binding. So we set off for home, only to feel the brakes starting to pull again after about 1/4 mile. Same thing again, after a period of time we could move and get a bit further up the road. I didn't have any tools with me, no breakdown cover and no phone a friend available, so we made it home in this fashion about 2 hours later (luckily we were only about a mile from home). I'm thinking it may be a problem with the master cylinder, since disconnecting the vacuum to the servo had no effect and the chances of both front callipers sticking at the same time is unlikely. I've had the car jacked up and there's nothing obvious wrong.
So what I'm asking is do you reckon it's the master cylinder, if so is it reasonably easy to remove/replace (I'm fairly handy with a set of spanners and generally tackle most things myself) and finally do you guys have any other suggestions before I start into a process of elimination.
Bit of a wordy one here but I've tried to give as much info as possible.
Thanks in advance
Andrew.
Thompy is offline   Reply With Quote
Old 28-04-13, 09:24 PM   #2
Master cylinder was sticking on my CQ but nowhere near as bad as what you're describing. If you get it to do it again what about releasing the M/C from the servo.....if brakes then free off it would suggest linkage(if there is much linkage??).
Strange that the pedal went hard??
Old 29-04-13, 06:12 AM   #3
Cuppatea
Cuppatea's Avatar
I saw this happen years ago on a 2.7 bi-turbo a6 auto, but it went to audi for diagnosis, same problem - solid pedal!
Check the bulkhead scuttle drains aren't blocked, the servo may have drawn in some rain water?
Cuppatea is offline   Reply With Quote
Old 29-04-13, 02:23 PM   #4
missfire
missfire's Avatar
Originally Posted by Thompy View Post
any other suggestions before I start into a process of...
Vagcom it maybe, any lights on? There is a bit of the servo hose that cracks and people epoxy it back together, causes hard pedal obviously, but jammed on calipers.. who knows, ESP/ABS problem maybe? The brakes on mine are cr*p! Calipers are free, pads are fine, hoses fine, going to check mine over next weekend, have lots of new bits to go on... Will soon find out if it makes any difference.
Old 30-04-13, 09:05 PM   #5
TeXerv
TeXerv's Avatar
When this symptoms appear again pour some cold water onto the master cylinder (water must not get in contact with brake fluid reservoir). If the break releases quickly, the master cylinder, especially the Central Valve is blown.
Old 30-04-13, 09:12 PM   #6
styler
styler's Avatar
when i worked in a garage in philadelphia, a chrysler lebaron came in with a similar problem, would drive fine for a while then the brakes would jam on leave it sit and cool and it was fine, till it heated up again.. .. when i checked the resevoir it looked as if there had been oil poured into it (instead of brake fluid ) so we changed the master cylinder and flushed the brake system, solved the problem.. maybe not whats wrong with yours but theres a wee story for ya anyway..
CRASH VALLEY CUSTOMS
get 'er done...
Old 08-05-13, 09:42 PM   #7
Thompy
Thanks for all of the replies. Didn't get a chance to look at the car until the weekend. Following styler's story above I thought I would check the fluid first as that would be an easy and cheap fix. When I compared the fluid in the reservoir to the bottle of Dot4 I have there was a significant difference in both colour and consistency/texture. The fluid in the reservoir was greenish/blue vs brown and it was quite a bit "thicker". So I flushed the system with new Dot4 and have done about 250 miles since with no problems.
Bit of a strange one, I know I've only ever put Dot4 fluid from local motor factors in and that was when I had a flexi hose develop a pinhole and I topped it up enough to get it to a branch of Farmers Autocentre to have the hose replaced as I didn't have time to do it myself. That was about 2 months / 1500 miles ago though.
Can't say I've paid much attention to the brake fluid in the 18 months I've owned the car apart from checking the level every now and again, so don't know if the colour/consistency has changed in that time.
Is it normal for there to be such a difference between "new" and "used" fluid?
Again thanks for the comments and pointers and I'm just glad that the problem is (hopefully) fixed
Andrew
Old 08-05-13, 10:14 PM   #8
missfire
missfire's Avatar
Bought a wee 80 last year that looked like it still had the original fluid in it! Fekn like black-brown treacle, chunks of rusty-all-kinds-of-stuff coming out. Flushed it.. obviously. a change every couple of years would be good in an ideal world, with plenty of spare time. Cheap enough to do, if yer nipples hold up!
